Browse Forums Owner Builder Forum 1 Jul 21, 2015 4:15 pm Hi, got a question to seeks advise. We are at a point to connect to sewage and storm water points. Found the sewage point but unable to find the storm water point. From the council storm water drawing the closest storm water discharge point is 2 property away. The question I have is, there was an old house before we knock it down to build a new house. The gutter pipe was going into the ground. During demolition, found some terracotta pipes from the gutter pipes. If there is no legal storm water discharge point in the property, where would the storm water get discharged. The old house was built in the early seventies. Thanks. Re: Storm water discharge point 2Jul 21, 2015 5:05 pm It's not unusual for older properties not to have a surface water discharge point. This link explains a bit more and provides some ideas on what next http://www.anewhouse.com.au/2014/08/sto ... rge-point/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Storm water discharge point 3Jul 21, 2015 5:20 pm Hi Bashworth, thank you for the information. Contacted the council and looks like I need to have to connect to a legal point 2 properties away. They do not allow discharge to the kerb. Looks like I will be a few thousands out of pocket. Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 7678 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 6656 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 5999 |
