Browse Forums Owner Builder Forum Re: OB Project - "New vs Old" - Nedlands, WA 201Apr 17, 2016 10:07 pm How exciting .....bugger about the tree though <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: OB Project - "New vs Old" - Nedlands, WA 202Apr 17, 2016 10:39 pm Yeah we have a boundary flame tree that is dropping limbs. This one hit the upper roof and gutter. Gutter will need to be replaced OB Project - "New vs Old" - Nedlands, WA 203Apr 17, 2016 11:00 pm Let's start to talk finishes..... The fixtures and fittings of our house are going to be a combination of aged brass, black and white. I think the combination works really well together. Starting off with the original house we will be reusing the original Art Deco style brass handles. We have had them ebanoled. It cost us $10 each. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The new section of the house will get new olivari handles also ebanoled. I think it will contrast well with the black steel doors. See handle for new section but in aged brass. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OB Project - "New vs Old" - Nedlands, WA 204Apr 17, 2016 11:30 pm Getting ready for my two large steel windows in the family room. All I seem to be doing these days is painting. I've put three coats of protection in preparation for onsite installation. They will get fabricated onsite as each window will weight about 300kg without glazing. Once installed I will apply 2 more coats. - it's never ending! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OB Project - "New vs Old" - Nedlands, WA 207Apr 22, 2016 12:15 pm Installing my light track recess today in preparation for the ceiling fixers. Not really sure how it's normally done but I've designed mine as follows. The internal sections will all the painted Matt black. I'll paint them over the weekend before the ceilings start on Tuesday. My track is an L shape and is just over 4m in each direction. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ OB Project - "New vs Old" - Nedlands, WA 208Apr 25, 2016 5:07 pm Ceilings going on today!! Starting to look like our home. I'm really pleased with our track recess. It's turning out exactly as I'd imagined. I have painted it with two coats of acrylic matt black. I've had to guide our ceiling guys through it as they found my request slightly odd initially but they have done a great job. mm perfect!! He asked me how exact it needs to be and I gave my usual "within half a mm is ok" answer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OB Project - "New vs Old" - Nedlands, WA 209Apr 26, 2016 9:43 pm Kasra, I'm not sure what measurements you did them at but Ezyjamb had this product http://www.ezyjamb.com.au/index.php/ezy ... or-jambs-6 = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = = Custom owner build in Hume - VIC - Tiling Stage http://goo.gl/qpPglB OB Project - "New vs Old" - Nedlands, WA 210Apr 27, 2016 10:38 am I can't believe I hadn't heard of Ezyjamb before you mentioned them for your door jambs. Their product lineup is very complete. - next house In this case I wanted to not be able to see the vertical section of the recess to give more of a dark void look. I set the sides in about 30mm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: OB Project - "New vs Old" - Nedlands, WA 211Apr 27, 2016 10:46 am More ceilings done. Upper ceilings almost complete. Lower ceilings starting Monday. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm not sure if I have ever showed this room. It wasn't on the original plans. Once we started building we realised we could have an extra room for very little cost. Couldn't have any windows so went with two openable velux skylight/windows. - the reveals are still to be done. Re: OB Project - "New vs Old" - Nedlands, WA 212Apr 27, 2016 2:16 pm Great thing about owner build is seeing something whilst it's still a work in progress and being able to change it for functionality or aesthetics. We have changed sooo much from original. Biggest was adding a whole extra walk in robe, and not a small one mind you. Got rid of wasted space, made the room more symmetrical and serves a purpose! Build thread: viewtopic.php?f=38&t=75302 Re: OB Project - "New vs Old" - Nedlands, WA 213Apr 27, 2016 2:21 pm Agreed! Total control! We too have made so many changes. Re: OB Project - "New vs Old" - Nedlands, WA 215Apr 29, 2016 8:32 pm Would love to know what kind of insulation you chose, and why? Also, what your internal wall diameter is - our walls are going to be something like 9cm so not much room to play with... OB Project - "New vs Old" - Nedlands, WA 216Apr 29, 2016 9:30 pm Hey Keffuful, we chose the Bradford gold for external wall. Our walls provide 14cm cavity so we went with two 70mm batts to give 140mm. Ended up with R4.4 Ceilings we are R4.0 And interval walls we are R3.3 soundscreen. Re: OB Project - "New vs Old" - Nedlands, WA 220May 05, 2016 6:14 pm Some more progress. Really happy with the way the reveals on the the openable windows turned out. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our ground floor has been prepared for the set coat. We decided to place the beads in the set coat rather than the float to get sharper corners. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16711 If you need to pay for a project manager you would be well advised to just engage a builder who would take full responsibility for the build. As opposed to you OB where… 5 15079 |
