Hi all
Looking at the possibility of using the unitex system and was wondering if anybody else has used the system , as I would like to get as much insulation into my build as possible .
Browse Forums Owner Builder Forum Re: unitex 3Dec 11, 2014 7:34 am They do a complete system with insulated panels that are fixed to the external face of the timber frame and then acrylic Render on top. The website looks quite good was wondering if anybody had used the system to enable feed back on cracking etc after a few years of being installed Re: unitex 4Dec 11, 2014 10:41 am Tim, Unitex is basically just another EPS sheet with an acrylic render over the top. There are quite a few on the market now. The installation and finishing are all pretty much the same. Stewie Re: unitex 6Jan 30, 2015 10:32 am Tim65 They do a complete system with insulated panels that are fixed to the external face of the timber frame and then acrylic Render on top. The website looks quite good was wondering if anybody had used the system to enable feed back on cracking etc after a few years of being installed Hi Tim65 Durability may well be a problem as well as ,structural integrity,delamination of material, and the list goes on.... If i were you i would be asking the manufacturer to provide all relevant data and info pertaining to your specific needs,build, environmental conditions, and the list goes on... Generally when building elements/systems fail it is because of couple effects (Heat, stress,chemical,material deterioration,With time,etc) that may not have been taken into consideration before hand.HTH Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs |
