Hi everyone, I am finding that tradies are not used to doing contracts. It seems, most work for builders, and are a bit unsure when it comes to filling them out. Does everyone use contracts for everything over $1000 ??
Cheers Alan
Browse Forums Owner Builder Forum 1 Sep 27, 2014 11:14 am Hi everyone, I am finding that tradies are not used to doing contracts. It seems, most work for builders, and are a bit unsure when it comes to filling them out. Does everyone use contracts for everything over $1000 ?? Cheers Alan Re: Contracts 3Sep 27, 2014 2:02 pm Hi Alan62, Instead of using a formal contract, can't you just put down in writing the specs of the job and take their written reply confirming the specs as your "contract"? I've taken to doing this after a bit of a fiasco with a concreter. The only caveat is that you need to be sure of the specs of the job and list them in detail - because whatever you leave out will not be part of the "contract". If I were a "tradie" I would feel more comfortable taking on a job that was clearly described as well. Re: Contracts 4Sep 29, 2014 1:16 pm Liliana Hi Alan62, Instead of using a formal contract, can't you just put down in writing the specs of the job and take their written reply confirming the specs as your "contract"? I've taken to doing this after a bit of a fiasco with a concreter. The only caveat is that you need to be sure of the specs of the job and list them in detail - because whatever you leave out will not be part of the "contract". If I were a "tradie" I would feel more comfortable taking on a job that was clearly described as well. +1. I would not engage a tradie without something written down (even informally) and signed by both parties. A tradie who refuses to do this cannot be trusted and would not be engaged by me. MBA and HIA both have sub contract agreements, check them out 2 7327 Industry type domestic contracts are prepared by industry bodies for the benefit of the builders. This means that if you are the owner watch out. One of the points is… 0 3235 |
