Browse Forums Owner Builder Forum 1 Sep 20, 2014 9:55 am Hi all, Just a quick question in regards to bamboo flooring for upstairs, the bamboo supplier has allowed for scotia in supply/install now does that mean I can get away with installing skirting boards? Pls advise on your opinions if it's advisable to have skirting board installed and then scotia or scotia would be sufficient. Thanks, Re: Bamboo floor boards 2Sep 20, 2014 1:04 pm The scotia is normally used if the skirting is already fitted, you can lay the floor then fit the skirting then theres no need for the scotia. I havent had a lot to do with bamboo floors as we usually put timber in our houses, but ive seen 2 recently and to be honest was not that impressed. In both cases the amount of shrinkage was to the point the floor in one ended up with an 8mm gap between the edge and the skirting. I know for a fact one of these floors was in a display home and was supposedly a high end product. Re: Bamboo floor boards 3Sep 21, 2014 9:15 am thanks mgilla, that's what I am trying to find out.. I am trying to find out if the scotia will act as a substitutef for skirting board? I do note the scotia is not as wide as skirting board which say will be around the 90mm mark Re: Bamboo floor boards 4Sep 22, 2014 9:23 pm gav89z thanks mgilla, that's what I am trying to find out.. I am trying to find out if the scotia will act as a substitutef for skirting board? I do note the scotia is not as wide as skirting board which say will be around the 90mm mark Hello matey Yes you can use Scotia instead of skirting board, skirting board looks better but obviously there is more cost involved. Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 389 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1932 |
