Browse Forums Owner Builder Forum 1 Sep 09, 2014 10:34 pm Hi, I am currently building a new house (owner bldr) and as it is difficult to get tradies out where I am, so I want to plan where everything goes first before I get a plumber out. What I need to know is where can I install the two gas bottles I want to install and make the slab for them to go on? I understand that there needs to be 500mm clearance above bottle outlets and 1 metre clearance either side of bottles. Can I install them under a raised deck and someone told me that they need to be 7.5m minimum from the first appliance outlet....is that correct for NSW? I was hoping to be able to have it about 1.5m from the first appliance. Also, I am installing a split solar hot water system with instant gas backup (LPG) - is there some rule for where this can be installed? Again, I was hoping to mount the unit about 600mm from solar tank and 500mm down from deck...would this meet the code? I would greatly appreciate any guidance with these two issues....thanks Re: LPG gas installation requirements 2Sep 10, 2014 1:49 am I have read somewhere that when the gas plunder fits the system they will install pretty close to first appliance as to save on copper pipe. This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3674 I'm wondering if anyone knows what the requirements are of a builder to be eligible to hold Domestic Building Insurance for proposed works. https://www.dbi.vmia.vic.gov.au… 0 3335 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5200 |
