Browse Forums Owner Builder Forum 1 Jul 15, 2014 3:33 pm Q Joist lap or overlap. When installing new joists for extension, how much lap is needed to go past the old joists, or do they just need full bearing support over the width of bearer ? Thanks in advance. Wobbly Design from top down to ground , build from ground up Re: Joists , new too old ? 3Jul 16, 2014 8:54 am The main thing is that the new joist has bearing over the full width of the bearer. If you are going to tie the new joists to the old then sufficient lap should be allowed for nailing or bolting the two together which I think is 1 1/2 the width of the timber so 50mm joists = 75mm lap both ways which means lap the timber 150mm. If you are buying the joists at set lengths then just let them run past whatever is left over once you have trimmed the important other end. Stewie Re: Joists , new too old ? 6Jul 17, 2014 9:10 am wobbly, AS1684.4 is a simplified version of AS1684.2 as AS1684.4 only applies to residential buildings within certain size constraints. It is a bit like AS1684 for Dummies. It costs about $90 ~ $100 which is less than the cost of a box of Paslode galvanised nails Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 5854 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 14652 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16843 |
