Browse Forums Owner Builder Forum 1 Jul 11, 2014 7:31 pm hi all, i've had a bit of an issue, as I first had a quote for fascia/gutter by another company who had sent me a detailed quote and they supply/install metal barge and barge gutter.. We decided to award the works fascia/gutter/roofing to one particular company... I believe now the metal barge/barge gutter has been missed been trying to google what it looks like, i just have valleys atm.. is the metal barge and barge gutter critical? thks. Re: metal barge & barge gutter? where is this usually requir 4Jul 12, 2014 12:39 pm Seeing as you are having a tiled roof with no gable ends there should be no need for metal barge cappings. All the ridges and hips will have concrete ridges. Metal barges to me are a reference to gable ends. A metal fascia is another matter and is simply installed on the end of the rafters with a gutter or barge gutter fitted on to that. I think something has been lost in translation here. Stewie Re: metal barge & barge gutter? where is this usually requir 5Jul 12, 2014 1:18 pm Do you have any Dutch gables? A barge gutter may be referring to what I know as a dry verge. Instead of having a barge tile that wraps over from the roof down the front of the barge fascia, there is a gutter that sits behing the barge fascia, it's purely a looks thing and means you dont see a barge tile. Re: metal barge & barge gutter? where is this usually requir 6Jul 12, 2014 5:00 pm Stewie D A metal fascia is another matter and is simply installed on the end of the rafters with a gutter or barge gutter fitted on to that. I think something has been lost in translation here. Stewie This is it, thanks Stewie I climbed onto the lower roof and saw it on the end of the rafters with a barge gutter fitted onto that, and then the brick wall starts.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ pls confirm if whether this is a metal barge and barge gutter. thks Fine with me... just let 'em step in with some affordable (but good) gear... 12 5493 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4936 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8977 |
