Browse Forums Owner Builder Forum 1 Jun 17, 2014 4:19 pm Hi Can someone post 2014 cost estimate per M2 building. Also state level of finish single or double story and block condition location please. Type of building. Example My owner builder project in 2005 Altona Meadows Flat block of land Brick veneer single story 369M2 foundation raft slab Simple design high quality internal finish 2.7M ceilings render hard floor boards good quality fittings and appliances. exposed aggregate concrete all around house including landscape and pergolas $830 per M2 Or if compared with standard builder finish $650 M2 Thank you Re: 2014 owner builder cost per M2 2Jun 17, 2014 4:56 pm Hi buildwest There is no accurate simple answer to your question. The only way to work out the price is to do the actual quantities for labour and materials . When I price a home I use a general check price of around $1300/m2. This would cover the inclusions you stated. Owner building can reduce this figure significantly but the banks are only interested in what it would cost for a contract builder to build it for you. You can always download my detailed cost calculator and other free calculators based on current industry prices. This will take some time to get right and you need plans to be really accurate. Www.greenifyconsulting.com.au Good luck with it 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 Hi VK, I am now retired however I have stood beside over 300 owner builders in the past 18 years that have successfully built their own homes. First of all a building… 10 22663 |
