We have a 30yo solid brick house and planning a major renovation.
As part of the reno, I am considering converting the exterior walls to RBV.
I'd be interested in any thoughts or reactions anyone might have.
BTW we are in Melbourne SE.
Chris
Browse Forums Owner Builder Forum 1 May 07, 2014 6:10 pm We have a 30yo solid brick house and planning a major renovation. As part of the reno, I am considering converting the exterior walls to RBV. I'd be interested in any thoughts or reactions anyone might have. BTW we are in Melbourne SE. Chris Re: Convert Double Brick to Reverse Brick Veneer 2May 07, 2014 6:36 pm I think its a great but just wondering how you would do it. If you remove the outer skin of bricks, would this not damage the inner, I imagine they are joined somewhere. Also if you remove the outer skin can the inner support the structure as there is no frame. Or will you keep the wall as is and then just "hang" the insulation and cladding off a light frame - it just needs to be able to hold the cladding not support the structure and you have: thermal mass of double brick. http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Convert Double Brick to Reverse Brick Veneer 3May 07, 2014 7:44 pm I think you will need to consult an engineer on that one. Depending on what is in place, and what loads are on the walls it could be tricky. My gut feel is it is likely to be more trouble (and expense) than it's worth. Presuming you are looking to do it for insulation properties. If so maybe consider alternatives, like in wall cavity insulation. It has it's own drawbacks but worth considering. https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: Convert Double Brick to Reverse Brick Veneer 4May 08, 2014 10:35 am In standard double brick construction it is the internal walls that carry all the load. The only thing the external walls carry is the eave lining. The window and door frames are also normally tied in to the external brick. As I said that is in standard construction and there are variations on this so you would need to check. It would technically be possible to do what you want too do, however it would be very expensive. As Rob said, cavity insulation may be a cheaper exercise. When I built our house I built the western double storey wall in RBV. I had the brickies brick the internal walls first, complete with windows and then I framed up around this and insulated and sheeted everything. It worked fine, and is essentially what you are going to try and do. There is not a great deal of information about RBV so it's important to have a competent carpenter who can work through the little issues you will face. Good luck. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Convert Double Brick to Reverse Brick Veneer 5May 08, 2014 11:47 pm You could clad the exterior in polystyrene and render it, giving you a double leaf of brickwork inside the insulation envelope. Not sure how you would attach it though... Some kind of adhesive perhaps? Re: Convert Double Brick to Reverse Brick Veneer 6May 14, 2014 1:17 pm Need to consider the detailing at external windows & doors. May be ugly unless this is detailed well. In particular if there are awning sash windows, make sure that windows can still be opened. 5 10476 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6628 2 8358 |
