Browse Forums Owner Builder Forum 1 May 02, 2014 9:31 pm Hi all, got a few questions in regards to brick work 1) expansion joints, what material can be filled inside to make it blend into the brick work, 2) in regards to the brick flashing above garage who is usually responsible for that? As I wont have roof tiles installed until after bricking is complete due, is it the responsibility of roof tilers to water proof the roof by installing lead flashing ? many thanks Re: Bricking - questions expansion joints lead flashing on r 4May 04, 2014 2:25 pm gav89z lead flashing ? Will you be collecting rainwater for possible potable use? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Bricking - questions expansion joints lead flashing on r 5May 04, 2014 2:33 pm Hi, SaveH2O We will only be using the tankwater for gardening, washing car, toilets, laundry.. I am now thinking of either using Wakaflex (lead free) flashing, if we are using the water collected from the roof for gardening, as the lead may leach into the water used for gardening ? Re: Bricking - questions expansion joints lead flashing on r 6May 04, 2014 3:50 pm Probably a good idea if the option is not an issue. It is generally recognised that vegetables, particularly the fruiting ones, do not accumulate lead from high lead soils but leafy vegetables can have higher concentrations. This may be because of directly watering onto the crop...I'll have to do some Googling and try to find some credible studies when I have the time. The link below is an interesting read, particularly if you drink coffee away from home! http://lead.org.au/lanv8n1/l8v1-11.html 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Bricking - questions expansion joints lead flashing on r 7May 05, 2014 1:58 am gav89z thanks JB1, or can the brick sealer also do the job of installing the biyseal foam and caulking it? cheers Brick sealer? The foam is just normal foam that is installed as brickies lay the bricks. I forgot to mention you push in a round backing rod before caulking the expansion joint. Re: Bricking - questions expansion joints lead flashing on r 8May 11, 2014 10:54 am Just a heads up for anyone, bought Lead flashing manufactured by ConsolidatedAlloys and is fully compliant with Australian Drinking Water Guidelines for potable water use, i.e. water runoff from roof catchment and into rainwater tank. I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10625 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6277 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10148 |
