Browse Forums Owner Builder Forum Re: 39 sq double storey home - number of bricks? 2Apr 09, 2014 4:21 pm Its time to do a little math and work it out, why guess it and end up with $1k worth or extra bricks on site or be half a pallet short. If you work on 50 bricks per sqm you should be able to do a fairly accurate takeoff. Theres a pretty fool proof way to do it. Sit down with the plan and calculate the wall height from the footing on a conventinal slab or 100mm below slab on a waffle slab to the top of upper wall. If you have eaves take off 300mm, now go to your plan and work your way around the house, multiply the wall length by the height you have. As you do a wall mark it off so you know its done. Work out the entire external wall area of your house, this will include windows and doors. Now go around both levels and work out window and door area and subtract it from he total wall area. You need to work out sill brick numbers, add together the width of all windows and doors then divide by 86mm, add that to your total above. Allow for piers, a 350x350 pier will use 46 bricks per metre, a 450x450 pier will use 70 bricks per metre. Once you have a total number write it down, this is the what you pay the brick layer on. Add 5% waste to this number and this is what you order to site. Thers no standard answer based on house size, window/door size and numbers can change the total by huge numbers. Hope that helps. Re: 39 sq double storey home - number of bricks? 3Apr 09, 2014 4:36 pm You will find some tables that give you the number of brick per length of wall and how many bricks for different heights here: http://www.anewhouse.com.au/design-tables/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: 39 sq double storey home - number of bricks? 4Apr 09, 2014 6:52 pm mgilla Its time to do a little math and work it out, why guess it and end up with $1k worth or extra bricks on site or be half a pallet short. If you work on 50 bricks per sqm you should be able to do a fairly accurate takeoff. Theres a pretty fool proof way to do it. Sit down with the plan and calculate the wall height from the footing on a conventinal slab or 100mm below slab on a waffle slab to the top of upper wall. If you have eaves take off 300mm, now go to your plan and work your way around the house, multiply the wall length by the height you have. As you do a wall mark it off so you know its done. Work out the entire external wall area of your house, this will include windows and doors. Now go around both levels and work out window and door area and subtract it from he total wall area. You need to work out sill brick numbers, add together the width of all windows and doors then divide by 86mm, add that to your total above. Allow for piers, a 350x350 pier will use 46 bricks per metre, a 450x450 pier will use 70 bricks per metre. Once you have a total number write it down, this is the what you pay the brick layer on. Add 5% waste to this number and this is what you order to site. Thers no standard answer based on house size, window/door size and numbers can change the total by huge numbers. Hope that helps. thank you kindly.. Re: 39 sq double storey home - number of bricks? 5Apr 09, 2014 6:53 pm bashworth You will find some tables that give you the number of brick per length of wall and how many bricks for different heights here: http://www.anewhouse.com.au/design-tables/ thanks bashworth, regards. Re: 39 sq double storey home - number of bricks? 6Apr 10, 2014 1:06 pm Don't forget to take into account window openings, doorways etc. They wont have bricks in them so you have to allow for the m2 area of those. Also you need to order different bricks for different areas such as 3 courses of Longreach above all doors and windows to prevent cracking. Possibly Solids in some area under Window sills etc. If you send your plans to your preferred Brick supplier they will accurately do the brick quantities for you for a small fee (From memory less than $100) Well worth it and certainly a far better option than guessing https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: 39 sq double storey home - number of bricks? 7Apr 10, 2014 7:05 pm docker_rob Don't forget to take into account window openings, doorways etc. They wont have bricks in them so you have to allow for the m2 area of those. Also you need to order different bricks for different areas such as 3 courses of Longreach above all doors and windows to prevent cracking. Possibly Solids in some area under Window sills etc. If you send your plans to your preferred Brick supplier they will accurately do the brick quantities for you for a small fee (From memory less than $100) Well worth it and certainly a far better option than guessing Thanks for the suggestion, I will look into it. Re: 39 sq double storey home - number of bricks? 8Apr 11, 2014 8:52 am docker_rob Also you need to order different bricks for different areas such as 3 courses of Longreach above all doors and windows to prevent cracking. Possibly Solids in some area under Window sills etc. I would suggest the house build is in the Eastern States so no internal bricks Re: 39 sq double storey home - number of bricks? 10Apr 18, 2014 8:37 am Smaller jobs we used to allow for 6 bags of brickies sand + 1.5 bags cement to lay 250 bricks Bigger jobs --> 1.25 tonnes of brickies sand + 3.5 bags of cement lays 1000 bricks. It depends on your brickies too - some waste a fair bit more than others. What bricks have you chosen ? Stewie Re: 39 sq double storey home - number of bricks? 13Apr 18, 2014 7:03 pm Stewie D Smaller jobs we used to allow for 6 bags of brickies sand + 1.5 bags cement to lay 250 bricks Bigger jobs --> 1.25 tonnes of brickies sand + 3.5 bags of cement lays 1000 bricks. It depends on your brickies too - some waste a fair bit more than others. What bricks have you chosen ? Stewie Thanks Stewie for the info, we are going for Austral Gunmetal Blue - Face brick.. Cheers. Re: 39 sq double storey home - number of bricks? 14Apr 18, 2014 7:10 pm mgilla gav unless your laying them yourself dont even go there, just ensure the price you get from your brickie incluses supplying. Hi, I am in favour of supplying my self as the price is quite inflated if I go through the brickie.... Re: 39 sq double storey home - number of bricks? 15Apr 18, 2014 7:12 pm JB1 Most brickies won't want to supply. Too much risk for them- theft and you not paying. I am concerned about the theft issue, have to take the punt... Might just initially order one pallet, which I believe has around 72 bags of 20kg Blue Circle cement. How's bluecircle, I believe it's by Boral.. So hopefully can't go wrong.. Re: 39 sq double storey home - number of bricks? 16Apr 18, 2014 8:46 pm JB1 Most brickies won't want to supply. Too much risk for them- theft and you not paying. Interesting comment. I'm trying to get some quotes from brickies that include supply of bricks (Boral Winter Gold in double height), and very few come back with a quote or a comment of 'buy them yourself' if they're worried about theft. Personally I would've thought that getting a brickie to supply would be cheaper as surely they buy much larger quantities over a year that we could dream of. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: 39 sq double storey home - number of bricks? 18Apr 19, 2014 12:25 pm Most brickies I've encountered here in Sydney don't want to supply anything. You have to supply the lot - bricks, sand, cement, plasticiser, DPC, brick ties etc. The only thing they want to supply is labour. Stewie 1 4588 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9977 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8201 |
