Browse Forums Owner Builder Forum 1 Mar 30, 2014 2:55 am Hi - at the stage of having my plans approved and pulling together my budget. Struggling to get a quote for flat roofing though. I'm not looking at a huge area - about 33m2 in total. Any ideas what the cost will be to have this supplied and installed by a roofing plumber? Cheers Re: New project : flat roof cost 2Mar 30, 2014 6:05 am Hello rudiger, I am also at about the same stage as you, maybe 50sqm of colourbond. last time i bought roof sheeting(approx 5 yrs ago) colourbond was 20-30$ mtr. Got no idea of cost of install but asume you will be putting bats and or sisalation to add to the cost. wobbly1 Design from top down to ground , build from ground up Re: New project : flat roof cost 4Mar 30, 2014 10:48 am I am currently getting quotes for a flat roof replacement, and a ballpark price per square meter installed is coming in at roughly $100. I'm waiting on written quotes to confirm this, but I think that includes battens and the blanket insulation that goes under the metal, but batts in the ceiling will be additional, as will fascias, etc. Re: New project : flat roof cost 5Mar 30, 2014 9:14 pm Nibbles55 I am currently getting quotes for a flat roof replacement, and a ballpark price per square meter installed is coming in at roughly $100. I'm waiting on written quotes to confirm this, but I think that includes battens and the blanket insulation that goes under the metal, but batts in the ceiling will be additional, as will fascias, etc. Thanks, and this makes sense. When I work out the square metre size of the roof itself i.e. no labour etc, I get to about $1k. Therefore I'd expect a couple of grand on top. Good luck! Re: New project : flat roof cost 6Apr 09, 2014 3:47 am hi rudiger, my costs seem to be more in the rafters for the build with, lvl 150 x 38 section beams at 450 centres over a 5m span + insulation + roof sheeting. So need to add aprox another 2500 to the cost of roof Design from top down to ground , build from ground up Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18306 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13905 |
