Browse Forums Owner Builder Forum 1 Feb 12, 2014 10:17 pm Hi all, I am considering doing my own roofing, and was investigating whether a licensed plumber needs to do the job for me. It depends on the State that you are in. I am in Victoria, which seems to have the most regulations. So, I had a quick look at the Victorian Plumbing Regulations: http://www.pic.vic.gov.au/about-us/vict ... ory-system All plumbing work must comply with Part 12A of the Building Act 1993 and the Plumbing Regulations 2008. Part 12A of the Act sets out the legal framework for the registration and licensing of plumbing practitioners, and regulation of plumbing work and other plumbing matters. The Regulations are derived from the Act and set out the requirements that must be complied with. Building Act 1993 http://www.vba.vic.gov.au/?a=5816 221D Plumbing work only to be carried out by licensed or registered plumbers Plumbing Regulations 2008 http://www.legislation.vic.gov.au/Domin ... -136sr.pdf 10 Meaning of plumbing work (1) For the purposes of section 221C of the Act the following plumbing work is plumbing work to which Part 12A of the Act applies— (a) backflow prevention work; (b) drainage work; (c) fire protection work; (d) gasfitting work; (e) irrigation (non-agricultural) work; (f) mechanical services work; (g) refrigerated air-conditioning work; (h) roofing (stormwater) work; (i) sanitary work; (j) type A appliance conversion work; (k) type A appliance servicing work; (l) type B gasfitting work; (m) type B gasfitting advanced work; and (n) water supply work. PART 9—ROOFING (STORMWATER) 30 Roofing (stormwater) work defined (1) Roofing (stormwater) work is the construction, installation, replacement, repair, alteration, maintenance, testing or commissioning of any roof covering or roof flashing and any part of a roof drainage system involved in the collection or disposal of stormwater, which connects to ground level and includes— (a) the connection of any stormwater piping to— (i) a below-ground stormwater drain; or (ii) an on-site retention or storage tank; and (b) any design work that is incidental to, or associated with, any work described in this subregulation. (2) Roofing (stormwater) work does not include— (a) any cleaning, painting or preparation work in relation to any item, device or equipment involved in the collection or disposal of stormwater other than the connection, disconnection or alteration of that item, device or equipment; or (b) the construction, installation, replacement, repair, alteration, maintenance, testing or commissioning of any roof covering consisting of non-metallic tiles, slate or flat membrane sheeting or any design work that is incidental to, or associated with, that work. I intend to install Asphalt Shingles, so I am able to install this roof myself. If it were a metal roof, you would need a licensed plumber to certify it. Hope this helps. For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 7731 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 773 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5720 |
