Browse Forums Owner Builder Forum Re: Advice needed from Tassy Owner builders 2Dec 31, 2013 8:14 pm My storybook home build: https://forum.homeone.com.au/viewtopic.php?f=38&t=57987 Re: Advice needed from Tassy Owner builders 4Jan 01, 2014 12:00 pm My storybook home build: https://forum.homeone.com.au/viewtopic.php?f=38&t=57987 Re: Advice needed from Tassy Owner builders 5Jan 01, 2014 7:35 pm Well so fare HCC is around $2k chraper than my council so lets just hope that since i'm paying more they are easier going with the bush fire reg's (yeah right ) What the hell,, so they are telling you what to build with and making you report every detail but at the same time getting you to pay a lawyer to draw up a legal document that makes them not responsible if the house does get burnt to the ground? Gee i'm not looking forward to dealing with it all. I am assuming though that they don't tick off all your BAL reg's until the final inspection ? I'm very interested to know this bit of info as i do have a plan Re: Advice needed from Tassy Owner builders 6Jan 06, 2014 10:15 am Also if any Tassy members have some good info on suppliers of good's and services please let me know below is a list of the things i am most interested in Soil Testing Septic tank suppliers roofing iron suppliers Concrete batching plants Rainwater tank suppliers Any help and or leads would be good. Cheers Re: Advice needed from Tassy Owner builders 7Jan 06, 2014 4:40 pm checkout the wormfarm system septics, as they can use zero electricity to run. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Advice needed from Tassy Owner builders 8Jan 07, 2014 9:29 am carter8 Also if any Tassy members have some good info on suppliers of good's and services please let me know... Yeah, sadly I can't think of anyone I'd actually recommend wholeheartedly. I bought my OzziKleen septic off MG Roberts and they seem okay, but hard to get in touch with. Roofing was by Raymark, and they were pretty ordinary at sealing gaps (I have a nasty feeling my building surveyor is going to point out the gaps that are >3mm, which don't conform to fire standards). Tassie is simply 1) too expensive, and 2) not competitive or hungry enough for work. My best advice is talk to as many people as you can, get recommendations, then get 4-5 quotes on each job. It's a struggle, but could be worth it. My storybook home build: https://forum.homeone.com.au/viewtopic.php?f=38&t=57987 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6961 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7054 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18539 |
