Just discuss with the brickie if there are any flashing waterproofing issues that need to be considered for the external doors.
Browse Forums Owner Builder Forum Re: Owner building in Jimboomba 22Aug 17, 2014 8:19 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 24Aug 18, 2014 1:35 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 25Aug 18, 2014 4:27 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Owner building in Jimboomba 27Aug 18, 2014 7:06 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 28Aug 19, 2014 10:47 am Damn, it sounds like you have done everything right but it is the clay soil that is letting you down. Perhaps the best option would be to have some kind of a trench that goes around the side of the house and down the hill to provide an outlet for the water to escape, perhaps into a longer gravel filled trench or perhaps into a 'pond' area that would only fill up when it rains, to give it time to slowly soak away. Since you are right up the back of the block it should give you some room to play with (neighbours permitting lol!). If you have a little trench/stream that wiggles back and forth then it would slow the water down and perhaps also look attractive as a landscaping feature? I guess if you were really desperate you could install a holding tank underground which would catch the water when it rains and then slowly drain it away through a gravel trench, but that would probably be overkill I was just helping my mum dig up her 30 year old greywater trench which had no drain matting over the slotted pipe and dirt all through the gravel, so of course the pipe was blocked with dirt and roots. It was good because it showed me what NOT to do as I am about to install my own! Re: Owner building in Jimboomba 29Aug 19, 2014 11:33 am I am now considering the option of leaving the black agi pipe in the ground, but adding slotted pvc pipes in different areas that I can direct via T pieces in to the black agi pipe that is just like the day I bought it internally. As the ground around the back of the house has to be raised by more than 300mm, I should be able to angle the slotted pvc towards the already buried black agi, stick some T pieces in, and some adapters, and my problem should be solved. A lot more time and effort, as well as money that I really didn't want to spend, and it should work fine. Any other suggestions more than welcome ! Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Owner building in Jimboomba 30Aug 19, 2014 11:58 am You could improve the surface drainage by putting down quarry rubble around the house and grading this to allow surface water to escape quickly. I did this for my build (I built on cut & fill) and it works. However the quarry rubble did cost a lot. The bonus is a have a clean, dry mud free build site. Above the cut, I also got the dozer doing the site levelling to make a small diagonal cut across the site to divert surface water coming down the hill around the build site. Re: Owner building in Jimboomba 31Aug 19, 2014 12:02 pm I think I'm a little bit too late for a lot of that. My target is to build up the earth closer to the slab itself, and have it slope away from the house, and to help it get rid of the water, agi pipes closer to the surface to take any of that water down the hill well away from the house. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 32Aug 22, 2014 6:28 pm bpratt My target is to build up the earth closer to the slab itself, and have it slope away from the house, and to help it get rid of the water, agi pipes closer to the surface to take any of that water down the hill well away from the house. Was the site cut sloped? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Owner building in Jimboomba 33Aug 22, 2014 8:26 pm SaveH2O bpratt My target is to build up the earth closer to the slab itself, and have it slope away from the house, and to help it get rid of the water, agi pipes closer to the surface to take any of that water down the hill well away from the house. Was the site cut sloped? Cut sloped ? House pad was cut flat, and I put black poly agi around the back then along the sides below the front. This black poly with sock on it has blocked up with I'm guessing the clay in the ground sealing the sock and even the slots in the black poly that I used that doesn't have sock on it. Here's a picture of the front of the block looking up to the house. :- http://www.oih.com.au/images/tower1.png The white thing sticking high up behind the house was a pvc pipe representing the overall height that my AR tower was going to be there. The back of the house is :- http://www.oih.com.au/images/tower2.png As you might see that's on the high side of the hill, where the water runs down to the house pad level, and where the agi pipes were laid, about half way between the alfresco and the bottom of the batters, then the agi pipes stretch around both sides of the house and down the hill past the house. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 34Sep 14, 2014 8:36 pm For those interested in my Amateur Radio tower, the first photo in the previous post shows the location of where it was going to go at close to the same height it was going to be as shown with the 100mm pvc pipe. Now if you could imagine if the thickness of that pipe times 4, which gives the actual width of the tower, from bottom to top. Not really an eyesore, particulary as I'll be adding trees and shrubbery throughout the front of the block up towards the house, so plenty of things to block the view of it from the road and nearby houses (all but the two on each side of us). Here's a picture from the front of our old home, when the tower was 15m in height. :- http://www.oih.com.au/images/tower-buccan.jpg Yes, you can see it, but it does have low'ish visual impact. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 35Sep 17, 2014 11:30 pm Finally got all my doors delivered on Monday, and have got my chippies lined up to install all the exterior doors. So pleased to have them finally delivered to the site. Got home today to find a email from my brickie advising that the builder he works for has now got him tied up until Christmas, and won't have any time to do my new home, so has advised me that he has to turn down my job. I really would like to keep him to do it, as he seems to take a lot of pride in his work, and I don't think I'll be able to get a new one in now, as it appears good brickies will be hard to find or a lot more expensive to get in. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 36Sep 18, 2014 11:23 am Bummer, but it does seem to be a recurring problem. Good brickies are hard to find so your guy might be worth waiting for. I'm sure there would be a lot of other stuff you or tradies could do on your house in the mean time. Stewie Re: Owner building in Jimboomba 38Sep 18, 2014 7:19 pm Stewie D Bummer, but it does seem to be a recurring problem. Good brickies are hard to find so your guy might be worth waiting for. I'm sure there would be a lot of other stuff you or tradies could do on your house in the mean time. There's not a lot to be done until the bricks go up. I'm not game to get the gyprocking done until after, as knowing my luck I will get 5 solid days of horizontal rain !!! Have just had the plumbing rough-in done yesterday, with council inspection booked for Tuesday. The doors arrived on Monday, with the chippies putting in the external ones tomorrow if they get time. Not sure if it is the right thing to put the internal doors in until after the gyprocking has been done. Externally there's 21 pallets of bricks right where I need to build up with fill. I don't fancy moving them around just yet. All that's pretty much left to do is manual digging work for me around the back of the house to ensure that there's plenty of drainage when we get rain here, so it doesn't sit around and soak under the slab... oh and run some more electrical in to the house... so far around 1400m of twin and earth, and another couple of hundred metres of cat6 and rg6. Oh, and all the bits and bobs of landscaping around the place. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Owner building in Jimboomba 39Sep 18, 2014 9:48 pm Quote: Not sure if it is the right thing to put the internal doors in until after the gyprocking has been done. Depending on your plasterers they can be a bit clumsy sometimes so the less things for them to damage the better. Quote: Oh, and all the bits and bobs of landscaping around the place. Well there's about a years worth of work right there! Stewie Re: Owner building in Jimboomba 40Sep 19, 2014 8:39 am Stewie D Quote: Not sure if it is the right thing to put the internal doors in until after the gyprocking has been done. Depending on your plasterers they can be a bit clumsy sometimes so the less things for them to damage the better. That's what I was sort of thinking, let them make their mess, and I can put in the door jambs afterwards. Quote: Quote: Oh, and all the bits and bobs of landscaping around the place. Well there's about a years worth of work right there! What do you mean, a years worth ? ... I see multiple years of work there. Sloping block and plenty of big rocks to deal with. The steep batters behind the house is going to be a big job in itself. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23886 Hi all. Anyone know when the $11,000 limit was set in legislation for renovations in QLD? Ive been renovating for 5 years now and this was the limit back then. As we know,… 0 4425 |
