Browse Forums Owner Builder Forum 1 Nov 10, 2013 8:50 pm I've got a raised concrete slab 8m x 3m and need to send plans to a "kit" shed supplier. I want the cladding to overhang the edges of the slab. (not sit on top, like the old shed) The finished shed should be two thicknesses of colourbond bigger than the slab, each way. If I supply my 8x3 plans, will they assume this is the outside of the frame OR the cladding? Do I need to re-label the plans to be 8.05m x 3.05m (@25mm/sheet guesstimation) If I explain my concern to the supplier, will I look like a complete moron? Re: Slab size vs shed plans 2Nov 10, 2013 9:20 pm No you won't look a moron just someone who is careful. The real morons are those that assume that everything is going to be OK without checking. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Slab size vs shed plans 3Nov 11, 2013 7:19 am Ask the kit maker whether their design is a 1. sit-on-slab, or 2.hang-over-the-edge style. If it is Type 1 , you then need to specify the length and width of the structure. If it is Type 2 , just give them the slab measurements. By the way, you can shorten or lengthen the cladding dimensions when you assemble by manipulating the colorbond sheet over laps. So even if you are a 20-30mm out, it can still be corrected. Re: Slab size vs shed plans 4Nov 11, 2013 10:07 pm After spending a day doing the circuit of steel shed suppliers, I am happy to say that they definitely DO NOT count the cladding into the measurement and they were generally happy with my plans. That seems to be the only commom factor between them. One wants $60 extra for a sliding door instead of a roller. Another wants $600 extra. One says a skillion roof is hard and expensive. The other says it's easy and cheap. One makes all sheds to an individual plan. Most will alter standard plans without problem. One was insulted at the concept of altering the designs in his pretty brochure. They all have different ideas of the local DA regs and/or if a DA was required. Topline Kearsley (agent for Fair Dinkum) ticked MOST of the boxes, so I might take the plunge tomorrow. One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 676 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4927 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5463 |
