Browse Forums Owner Builder Forum Re: Asbestos help please? 2Jul 02, 2013 12:33 am The only way to know for sure is to get it tested by a laboratory - asbestos removal companies can get this done for you (or you could locate one yourself if which may be cheaper). Re: Asbestos help please? 3Jul 02, 2013 12:15 pm When was the house built? Asbestos stopped being made in sheeting in the early 80s. If you can get a look at the reverse unpainted side of a sheet of the stuff, the markings and appearance should be enough for a qualified person to know whether it contains asbestos or not, without resorting to expensive lab tests. Re: Asbestos help please? 4Jul 02, 2013 12:52 pm My sister had some fibro tested for asbestos recently with Parsons Brinckerhoff, it only cost 30-something dollars so not expensive at all. Re: Asbestos help please? 5Jul 02, 2013 7:16 pm Cheer guys.....apparently it only about 10% asbestos? wonder if i can remove that myself? its only the ceiling under the carport i need to do. have been quoted about 800 for some one to do it. the house was build in 1976.. cheers Re: Asbestos help please? 6Jul 16, 2013 11:11 pm Mate, as a guy who has removed a lot of asbestos in my short years, some the right way and some the not so right way, just pay the money. Re: Asbestos help please? 7Jul 17, 2013 10:55 am Perthguy Cheer guys.....apparently it only about 10% asbestos? wonder if i can remove that myself? its only the ceiling under the carport i need to do. have been quoted about 800 for some one to do it. the house was build in 1976.. cheers Asbestos is no big deal depsite all the scaremongering. Just dont break it up in a way that fibres can become airborne and breathed in. 1. tape tissue paper over your nostrils with surgical tape, and tie a bandana or some type of cloth around your mouth, tightly. These two measures will stop any possible stray fibres getting into your lungs. You can buy a more expensive mask, but they are very uncomfortable. 2. Take each sheet down whole. You do this by removing the nails,etc usually by breaking the fibro around the nail . Do this slowly , and continually spray with a water bottle and nothing will become airborne. Have a second person spray it as you hit it and break it. 3. Once the sheets are on the ground, throw a hose over them, and break them up by standing on them. You can then put the pieces in small parcels. Ive removed tonnes of the stuff using the above method, no drama whatsoever.Some councils have laws that restrict how much you are allowed to remove, check if you insist on doing it by the book. What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7137 4 1834 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7158 |
