Browse Forums Owner Builder Forum 1 May 20, 2013 6:25 pm Hi all, as i got a couple of good responses from my last post i thought that i would float this idea also and see what you have to say. We are looking at putting on a Project Manager that is a WA builder to assist and oversee the entire process. I am currently in the throes of getting labour costings from some Tassie builders so that we can perhaps look at the option of bringing them over to Perth to do the build. I must say....HUGE difference in labour costs between Hobart and Perth. Significant savings even with the flights and accommodation. Any thoughts? Cheers Mel Re: ideas on bringing in building team from Tas to build in 2May 20, 2013 11:35 pm That just doesn't seem right. Our cost of living is higher than Tassie, but not to an extent it would make that much of a difference to cover the cost of living. Unless you are building out in the sticks and both teams would need to allow accomodation. Then again, if it is really quite on the apple isle they might just be desparate for work. Just got to weigh the pros and cons. It is hard enough to get a local tradie to turn up, from the other side of the country for a little bit of warranty work or if the job is going in stages would be a nightmare to organise. Re: ideas on bringing in building team from Tas to build in 3May 21, 2013 9:19 pm Interesting... Not something I would ever consider unless you knew the Trades personally (eg Family) (and I am one to do things a bit different having imported a container of stuff from the UK for our build) But for general trades I just cant see how it would work financially let alone trying to co-ordinate things to run in a timely manner. Say you have a Sparky flying in on X date but someone else hasnt finished there work or Supplies haven't arrived on site due to lack of stock or whatever. Do they stand around on full pay whilst they wait? It's not like they can head off to the next job in the meantime. Then theres things like how does your Chippy get his trailer load of tools to site? What about getting from the accommodation to the Job site? Need to get a Van for them all? Do you have to hire stuff for them locally? eg Brickies need a Cement Mixer which is a bit big for excess baggage and the list goes on and on. On top of that not sure how licensing works these days. I think electricians can work Australia wide but not sure on plumbers if they need to register locally or not. Maybe I am being too negative but I'd think long and hard before you commit to something like that and even then it would have to save a lot to be worth the hassle and potential cost over runs. If you do follow through though I'd be keen to hear how it all goes Good luck https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: ideas on bringing in building team from Tas to build in 4May 22, 2013 9:57 am This does sound a wee bit crazy (no offense). My builders' rates here in Tassie range from $45 plus GST for carpenters, to $65-$75 plus GST for project managers / leads. Then there's the 18% builder's margin on top of that. Hell, even labourers get over $40 an hour here. The only way you'd secure a cheap deal would be to find someone who's desperate -- and the only desperate builders in Tassie at the moment are the rubbish ones. My plasterers haven't been on site for 2 weeks as they're simply too busy. My electrician was tied up for a MONTH before he completed rough-in. Tassie isn't in as bad a state as you may have been led to believe... (If you do find a builder willing to travel for you, PM me with their details and I'll let you know if I've heard of them.) My storybook home build: https://forum.homeone.com.au/viewtopic.php?f=38&t=57987 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17199 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6137 Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 3949 |
