Browse Forums Owner Builder Forum 1 Apr 08, 2013 10:55 pm Hi there guys, Thoughts on turning my carport into a Salon for my wife to run as a business... I have had 2 quotes so far from 2 builders, 1 for 40k and 1 for 30k.......I am hoping i can do it form 17k as that is all we have. We have ample parking in the drive way for once customer at any one time and we also cut all the neighbors in the street so wouldn't be an issue there.... Trades i have sorted.... I am a fridgy myself so can do the A/C.. Neighbor is a gyp rocker and will help me. Best m8 is a Sparky. Another m8 is Plumber.. Where the Roller shutter door is i will put in new french doors. Where the gym is will be a toilet. the rear will just have one sliding door. My issue is what to do with sealing the floor? do i need to rip up the concrete and the lay new stuff down with a membrane? would this be cheaper than raising the floor off the slab but then i would have to raise the ceiling? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any help would be much appreciated..cheers Mitch. Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 2Apr 09, 2013 1:51 am I'd have thought you just need a waterproof threshold. Then just do what you intend to do with the floor. .ie; tile, lino, grind, hone or polish. Nothing that would be effected by moisture is worth consideration.... Where you are coming from is where you are going to... Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 3Apr 09, 2013 7:07 pm Thats what i would of thought....How can i get some info on what i need to do with the floor? Does anyone know if i need to rip up the concrete and lay new membrane down with new concrete or can i should roll on seal the original concrete? PlZZZZ help... Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 4Apr 09, 2013 9:27 pm As Onc says I cant see any reason you would rip up the Concrete. To undertake this "Build" you would need detailed plans submitted to council for approval. Give them a call and ask the question. Not sure of the front or how your water runs as per the picture but you might need to lower the paving at the rear to get some sort of Threshold there. Ask council though, Unless they say otherwise leave what is there alone and lay tiles or whatever straight over it. Worst case you could put concrete over the existing slab if you had to raise the height. Is someone suggesting you need to rip it up? Obviously that seed of doubt has been planted somehow? https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 5Apr 09, 2013 9:45 pm Ha, no just the builders that have come round for the quotes say that i need to do this... If i raise the floor i will need to raise the ceiling though.. But if i can get away with just brushing sealer onto the existing then that should be good.. So if the council accepts the plans of just than all system go, they can not change there mind then make be rip up the concrete? Should they be able to tell me over the phone? or do i need to subm it the plans and then let them decide? cheers Mitch. Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 6Apr 09, 2013 9:53 pm Hummm i have had a thought.. At the moment when the slab gets damp in winter etc the air over the top helps it dry out? If i seal the top of the slab then would this just be locking in the dampness into the concrete which would have no where to go? which would eventually fail and crack? Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 7Apr 09, 2013 10:40 pm Any change in use is going to need to comply with the BCA to get council approval, which im pretty sure is going to require removal of the slab and waterproof membrane installed underneath the new slab (0.2mm polyethylene film). If you are doing work yourself and with help from friends then 17k is realistic. If you need any help with drawings for council submission get it touch with me as I run a CAD drafting business. Neil.. Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 8Apr 09, 2013 10:45 pm Hey thanks for the info Pezz, So who is going to tell me what the building code should be for this...is it the council? then.. who should i speak to? will keep you in mind for the drawings.. Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 9Apr 09, 2013 11:32 pm Check the following info sheet for some guidelines, and speak to your local council building dept as they may be able to provide a similar info sheet. http://www.kalamunda.wa.gov.au/files/386255ef-dfba-4bff-ac62-a16300e5fcab/13BLDInfoSheet13_CovertHabitable.pdf Neil.. Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 11Apr 11, 2013 10:23 am I'm not sure if regulations in NSW are different, but my hairdresser operates from her converted garage at home - she said that she had to put in a particular type of lino - kind of like hospital lino that curves up the wall about 200mm. She didn't have to re-do the cement or anything as drastic at that Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 12Apr 16, 2013 5:43 pm Hummmm cheers Lynnny. I called the council and and they said pretty much that i had to rip up the concrete but then other methods may be ok.. its hard to get a straight answer out of them? Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 14Apr 20, 2013 7:41 pm Siloxane injection Where you are coming from is where you are going to... Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 16May 16, 2013 9:07 am Mostly vertical but will provide a water resistant barrier as a flood coat. Where you are coming from is where you are going to... Re: Newbie first OB carport into Hair Salon. Plzzzzzzzzzzzz 17May 16, 2013 7:59 pm Cheers m8, have emailed these last week but still no reply email yet? http://www.saltdamp.com.au/index.htm#intro.html a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8718 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7086 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 |
