Browse Forums Owner Builder Forum 1 Jan 17, 2013 6:58 pm Hi Forum, I am doing an OB and all has gone OK until today. The colourbond roof went on and the licenced installer's offsider has overtightened most of the screws - resulting in broken seals. The tradesmans fix is to return to the job and back off the screws that are too tight and remove and replace the seals of the broken ones..... There are a few hundred screws that need doing and he is talking just 2 hours to complete the repair. I suspect there is some issues with this proposed repair.....e.g. - how can the tension and weather seal be returned correctly if the roof screw is re-screwed into the same hole? Is this a recommended repair for overtightened fasteners? Any advice or guidance appreciated..... I can see what your saying....) Permits - 20/11/12 Site Work - 28/11/12 Slab - Due 4/12/12 Frame - Due 16/12/12 Roof - 17/01/13..????? Re: Bad Roof Job 2Jan 21, 2013 11:59 am If they have used long enough screws ( 50mm if they are going into softwood or unless you are in a high wind area ) into the battens then this shouldn't be a problem. Better to get the sheets screwed down with the seal in place and lose a minimal amount of extra hold-down power ( and you are probably talking a very small amount ) than not to have the screw seal in place or compromised. Stewie Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7048 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10415 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 11571 |
