Hi All,
i need to get a stair case made. Can anyone recommend a stairs case makers in the south east suburbs? What shoulde i expect to pay for stairs which we will not carpet roughly,
cheers john
Browse Forums Owner Builder Forum 1 Jun 03, 2012 8:07 pm Hi All, i need to get a stair case made. Can anyone recommend a stairs case makers in the south east suburbs? What shoulde i expect to pay for stairs which we will not carpet roughly, cheers john Re: stair case 2Jun 03, 2012 8:10 pm I dont think you should carpet anything roughly!!! Simple stair from $ 2400. @builderforlife Building inspector and passionate about construction When you need an expert to take a look. stair case 5Jun 19, 2012 10:10 pm Try "general staircase" out in the south west they work all around Sydney metro. Great quality JDTservices Renovation - Concreting - Landscaping - Sandstone Features - Pergolas & Alfresco URL: WWW.JDTSERVICES.COM.AU eMAIL: Sales@jdtservices.com.au Re: stair case 6Jun 26, 2012 9:11 pm I used signature stairs in melbourne. They did a terrific job, but it was pricey due to the american oak, glass balustrades embedded in the stringer and suspended nature of the stair case with an exposed underside I also had two flights. the glass hasn't gone in yet, but I couldn't recommend the company more highly. i think the only other company in their league is probably slattery Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ my house blog: http://sugarloafdrivebuild.blogspot.com/ Re: stair case 8Jun 28, 2012 9:29 pm I think it was around $25k in the american oak, with the glass slotted into the channel. There's probably three times as much glass in the plans as what you see here for the channel in the stringer, as there is a void upstairs that has glass balustrading, and there is glass balustrading around the side to prevent people falling down the lower flight of stairs. Most people probably have much more simple staircases and the cost would be a lot lower. It's also a lot less expensive if you have a wall to prop up the staircase - vs floating it the way that I did. I actually had to have the engineer strengthen the supporting beams up the top to enable the void/staircase to work. There's more detailed plans/photos on my blog. On my lower flight I had the steps blocked from underneath - a lot less labor - but since you can't see it, it doesn't matter. The upper flight, is completely exposed (no plaster lining underneath), so you see all the oak from the underside - so there's more labor involved in getting that finish. I can't wait to see it when it's all stained, floorboards are finished and the glass is in. my house blog: http://sugarloafdrivebuild.blogspot.com/ I'm curious, did they provide any reason why they did not like the idea? 1 22110 |
