Browse Forums Owner Builder Forum 1 May 07, 2012 9:24 pm Hey, hoping someone can help me decide this one. I have 2 plasterers quoting on the job, plasterer no 1 is telling me that i should put villa board under the alfresco, says its much better than wr plaster, will look better when painted and generally will do a better job, also said that wr plaster can sometimes pull through the screws. Plasterer no.2 says wr plaster is much better. Its cheaper and villa board needs an expansion joint, which looks ugly and it can crack. I dont know which way to go so i hope someone out there can help me. Site Cut 17.02.12 Slab poured 29.03.12 Frame up 23.04.12 Roof on 10.05.12 Lock up 18.07.12 Moved in 26.10.12 252 days or 36 weeks to complete. Re: Villa Board vs WR Plaster 2May 08, 2012 9:15 am You will end up with a much better result with WR plaster. However villa board is much stronger and you are supposed to tile and not paint over. The reason why villa board needs an expansion strip is because it will crack when you stop it with plaster. Re: Villa Board vs WR Plaster 3May 08, 2012 9:07 pm Thanks B star. I have to admit i was leaning that way but its good to get another point of view. Site Cut 17.02.12 Slab poured 29.03.12 Frame up 23.04.12 Roof on 10.05.12 Lock up 18.07.12 Moved in 26.10.12 252 days or 36 weeks to complete. Villa Board vs WR Plaster 4May 09, 2012 3:54 pm Hi Our kit home supplier originally specified water resistant plasterboard for the alfresco and verandah linings. We are in a cold climate where we get a lot of fog and heavy dew. Our builder recommended that we change it to villaboard as the plasterboard starts to sag after a while. Ours is painted and looks good Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2780 Thanks for clarifying. Sorry I misunderstood your point 7 6998 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5039 |
