Browse Forums Owner Builder Forum 1 Apr 18, 2012 1:56 pm Interested in peoples' experience in the cost of plumbing a new home. Kitchen, laundry, bathrooms, sewerage, stormwater. Excluding roof plumbing. What was your cost and a brief description of your scope. Thanks in advance. Nick Re: Cost of new home plumbing? 2Apr 19, 2012 7:23 pm Try a few more details, like house size!! bathrooms, toilets, ensuite, etc. location, site access, ground type ie rock etc, sewer/septic (I know it says sewage above but?), numbers of taps and type, location of stormwater and sewer, outside taps or similar, water tanks required, grey water systems, hot water systems, could go on but a bit more detail would be nice. Ps Forgot, having gas?? Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Cost of new home plumbing? 3Apr 19, 2012 9:21 pm My current project is a single level brick veneer home with bathroom, ensuite laundry and Kitchen. Water tank connected to toilet flushing. The sanitary plumbing is costing $ 2600. Newstormawter and sewer drains included. Let me know if i can clrify further @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Cost of new home plumbing? 4Apr 19, 2012 11:30 pm Drainage and connection of water (Tap installed at meter site) - pre slab $2600 (you can see my thread for pictures to give you and idea of size and location of plumbing) Internal plumbing and gas $5000 (didn't use copper, used the newer style yellow/purple pvc piping) Sewer and stormwater piping (200 )meters $4000 - used 100mm pipes, not 90mm (I have found that tradies add up in thousands most times) - we paid the excavator seperately $1100 Actual connection of downpipes to stormwater $500 Still waiting for internal fitout after plastering (fitting taps, toilets, showers etc..) Bear in mind we are owner building - most times we pay more for that privilidge, and the plumber is a childhood friend of my husbands' so we didn't shop around for quotes on plumbing - not sure if we got a cheap/reasonable/expensive job....and it's probably better that I don't know (Colorbond downpipes made up at $30 each) *Our house is set back 15mtrs from the boundary and is 27mtrs deep - and main bathroom is at the very back of the house *We also have recycled water that is run seperately to toilets and outside taps *We paid in cash Hope this helps Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16280 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6169 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7036 |
