Browse Forums Owner Builder Forum 1 Apr 08, 2012 3:42 pm Hi everyone, was wondering if anyone would be able to tell me if I am allowed to change a window type after my plans have been approved... by change i mean from a double hung window to an awning type (same glass thickness) just a style change?? This wouldnt affect the basix would it?? Re: Window Changes after Council Approval 2Apr 08, 2012 4:18 pm I am 99.99% sure it wouldn't be an issue (Not in Perth anyway) https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: Window Changes after Council Approval 3Apr 08, 2012 4:58 pm If everything is already signed/finalized, you might need to pay your builder a variation fee to make the change. Though some builders might reduce/waive the fee, depending. Re: Window Changes after Council Approval 4Apr 08, 2012 5:36 pm NathanC Hi everyone, was wondering if anyone would be able to tell me if I am allowed to change a window type after my plans have been approved... by change i mean from a double hung window to an awning type (same glass thickness) just a style change?? This wouldnt affect the basix would it?? Not an issue, window suppliers do it all the time. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window Changes after Council Approval 6Apr 09, 2012 8:46 pm Depends on your council though. Here they wouldn't let you do it as we are in a heritage overlay and they care very much about what type of window you use. It would mean resubmitting the plans for approval. Re: Window Changes after Council Approval 9Apr 16, 2012 11:36 am Just to pick up on Eds comment - not that I can very often. Speaking purely from a Vic perspective, once a 'Thermal Assessment' has been provided as a part of the Building Application documentation, the window type cannot be altered. Although altering a window from double hung to awning may seem insignificant, it may have a bearing on the input to the rating software & in a situation where the home is borderline it is possible a small variation could reduce the rating to below the required statutory level. In a 'perfect world' the building inspector should pick up on a discrepancy between the nominated windows in the rating & installed products. I have no idea of the Basix procedure in NSW but post this as general information. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Window Changes after Council Approval 10Apr 16, 2012 6:09 pm ausdesign Just to pick up on Eds comment - not that I can very often. Speaking purely from a Vic perspective, once a 'Thermal Assessment' has been provided as a part of the Building Application documentation, the window type cannot be altered. Although altering a window from double hung to awning may seem insignificant, it may have a bearing on the input to the rating software & in a situation where the home is borderline it is possible a small variation could reduce the rating to below the required statutory level. In a 'perfect world' the building inspector should pick up on a discrepancy between the nominated windows in the rating & installed products. I have no idea of the Basix procedure in NSW but post this as general information. Very good point... Make sure the u-value of the replacement is less than the specification in the energy report. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Window Changes after Council Approval 11Apr 16, 2012 8:25 pm I did my own Basix certificate and from what i understand and can remember Basix cares about m2 of glass, glass type and frame material. I don't think I specified the window opening type. I'm going to check now that I've said that. Have you anonymously called your council to do the research? Hi Minho I have heaps of experience in Ku-ring-gai with both DAs and CDC ( this is the main area we build in). DA's are taking 12-18months and CDC's we have been doing… 1 3148 1 2965 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11015 |
