Browse Forums Owner Builder Forum Re: Dropped ceiling - plywood or plaster? 2Mar 07, 2012 8:21 am https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: Dropped ceiling - plywood or plaster? 5Mar 07, 2012 2:20 pm suprok The lining will also used to improve the accoustic properties of the room as well - the walls are all insulated concrete forms, so the roof will be the "leaky" bit, both thermally & noise wise. Possibly a bit OTT, but I'm thinking the dropped ceiling will also make chasing the wiring much easier (plus cat6 cables, etc). I know it's 'doubling up', but originally we were going to install 2 sheets of plaster to deaden noise anyway. I don't mind the extra expense; just want to ensure I do it the right way! For acoustics you may also want to consider "Gyprock Soundcheck" - Only a few $$$ more per sheet compared to standard Gyprock, and from what I have heard works very well for reducing noise transfer. One of the Members on here put me on to it and I am planning on using it myself to lessen noise from an upstairs loft. https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4064 Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 13478 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5024 |
