Browse Forums Owner Builder Forum Re: Owner Building a PAAL Camden in the Lower Hunter Valley 141Jul 18, 2013 5:12 pm Just wanted to say what a gorgeous job you've done - Damn about your experience with some of the trades <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Owner Building a PAAL Camden in the Lower Hunter Valley 142Jul 22, 2013 10:29 am Thanks AKB, sorry to sound so whingy.......we really have met some fabulous tradesmen along the way...it's just that the bad experiences tend to stick in your mind much longer than the good. Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 143Jul 22, 2013 8:23 pm Hey I didn't think you sounded whingy Opps Initially auto correct wanted to say winery lol and I agree with everything in life it's the bad experiences that linger <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Owner Building a PAAL Camden in the Lower Hunter Valley 144Aug 13, 2013 9:52 am I don't know why I'm surprised.....I guess it's that we always say "Well, we learnt from that mistake....let's not let it happen again"....and then it happens again - poor workmanship, rushed job, overbearing tradie who says "That's how it's supposed to look....it's fine" and then rushes off to his next job... Rangehood installation........ Does this look like a quality job......let's not aim that high - would you consider this a passable job, is this how these rangehoods are meant to look once installed? We got a "PROFESSIONAL" to install it......... It's not level, it jiggles up and down when you hold the front corners and lift it up, the chimney extension looks crooked and moves when you putsh it toward the wall to try and fill the gap between the wall and the chimney part. The "PROFESSIONAL" couldn't find any studs in the right position - he assured me that gyprock fixers would hold the weight.....yeah?? Looks like it's going to fall off the wall at any minute. We have given them the opportunity to come back and fix it up....don't know what they plan to do with the gap in the ceiling and cornice.....he said yesterday that WE would just have to run some no more gaps around it.......and that WE would have to patch the hole he left halfway down the chimney. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 145Aug 13, 2013 10:33 am OMG That is shocking.....I would be Furious <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Owner Building a PAAL Camden in the Lower Hunter Valley 147Aug 15, 2013 9:38 am No, we don't have any left over....will have to buy another length, get plasterer in and hopefully it will look ok.....the "mob" are coming back Monday week...hopefully it's still hanging by then as it's slipped to even more of an angle..... Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 148Aug 15, 2013 10:49 am Oh lynny-jane I do feel for you - fingers crossed for a good outcome <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Owner Building a PAAL Camden in the Lower Hunter Valley 149Sep 16, 2013 10:40 am Finished......... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not finished.......... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 150Sep 16, 2013 1:42 pm Driveway looks fantasic .... Rangehood <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Owner Building a PAAL Camden in the Lower Hunter Valley 151Sep 16, 2013 1:48 pm driveway looks great, sorry about your rangehood. Re: Owner Building a PAAL Camden in the Lower Hunter Valley 152Sep 19, 2013 2:51 pm That rangehood flue cover is terrible. The heat and vibrations from work it's way loose from the plasterboard. I have another concern. It looks like you don't have a splashback. Not only is it a fire risk, but oil/fat will splatter and soak into the plasterwall. Are you planning on installing a splashback? I doubt it will pass Cert of Occupancy without one. Re: Owner Building a PAAL Camden in the Lower Hunter Valley 153Sep 19, 2013 9:17 pm Oh yes.... Splashback is going in AFTER the range installation is finished. As you see it now it has been pulled out of the ceiling hole and away from the wall so that the installer could patch a hole in the wall.......a few weeks pass.....we order some more plaster cornice.....wrong pattern turns up (apparently our fault ????).....re-order and re-pay for correct cornice.....a few more weeks pass...correct cornice delivered. It really has been a balls up in every instance lol !!! The installer is coming next week to finish the job - hopefully .....stay tuned. Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 155Sep 24, 2013 9:07 am I think we'll just go with a glass splashback.....to many options with tiles and I'm not good at making decisions, so at least with glass I just have to choose a colour Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 156Sep 24, 2013 11:40 pm I installed glass Splashback 3-4 years ago when I renovated but recently installed tiles. I think for your kitchen tiles would be more suitable. Furthermore you could install tiles right up to the cornices and then install the rangehood over the tiles. Anyway that's my opinion. Re: Owner Building a PAAL Camden in the Lower Hunter Valley 157Sep 25, 2013 8:25 am You're right of course.....tiles would suit better than glass as our house isn't ultra-modern. Thanks for the tip Looks like I'll be making a trip to the tile shop after all lol. Here I was taking the easy option....... Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 158Sep 25, 2013 10:37 am An alternative that I am looking at for Splasbacks, ( as well as showers and benchtops ) is a Ceramic slab called Laminam. Comes in sheets of 1000mm x 3000mm. From Italy, but locally from http://www.cdkstone.com.au/laminam/laminam The Italian site shows many other uses for it as well. http://www.laminam.it/en/ Re: Owner Building a PAAL Camden in the Lower Hunter Valley 159Sep 30, 2013 10:45 am I think I maybe miss the mess......... Yard work - after amassing a fair amount of fill and getting a couple of loads of topsoil we were ready to take the plunge and tidy up the yard...... Fill.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Topsoil Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wanna-be farmer or scarifying genius ???? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bobcat has done the job... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And finally......spread some grass seed and fertilizer around.....put down "some" turf (because we are penny pinching we didn't do it all....... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Invested in some good sprinklers and waiting for our water bill lol! Hubby putting some sandstone steps from veranda to the driveway today.... Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Owner Building a PAAL Camden in the Lower Hunter Valley 160Oct 01, 2013 8:25 am I am feeling positive today - the bloke is coming to fix our range hood installation. Fingers crossed for a great outcome Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4297 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11369 thanks guys! yes this is how I've exactly raised it with the builder. still awaiting response. 12 6053 |
