Browse Forums Owner Builder Forum 1 Oct 14, 2011 10:09 am Hi, I recently (2 weeks ago) had poured concrete (colured) ‘installed’ which covered a large area. It rained within 24 hours after the concrete was poured. I have found several small holes at the surface of the concrete. Almost seems to be caused by air in the concrete. The concrete also seems to flake of easily. Comments and suggestions are highly appreciated as it did cost a lot of money. Thanks guys. Re: PLEASE COMMENT- poured concrete (colured) ‘installed’ 3Oct 17, 2011 5:56 am I that happened on the renovators.. I think they had to repour the top layer because the rain weakened the top layer. ( I think he had to scrape some off) It was keenan talking from the weatherboard house. Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10688 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 |
