Browse Forums Owner Builder Forum 1 Oct 14, 2011 4:15 am Was wondering if anyone new if it is okay to increase the pad footing size to that from the drawings supplied by the manafacturer.Am about to start buildind a kit home the drawings call for footings 400x 400 mm square with a depth of 600mm was thinking of going 500x500 and 700 deep but am unsure if this is allowed or will council say that it's not to specifications Re: pad footings size 2Oct 14, 2011 4:34 am Generally more is better. The council could well ask for more during their inspection if they are not happy with the ground condition The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: pad footings size 3Oct 14, 2011 6:50 am Footings size, type of cement mix, and steel within - should all be determined by an Engineer I know Clay footings are different to sand footings and even then different clays and sands should have different footings. In sand a wider footing is better than a deeper footing and so on. It also depends what loads will be exerted from above (and sideways ) If it was me I would consult an engineer who would base the footing design on the load above as well as the soil type you have on your land. The thought of making a footing bigger than it needs to be or a "one size fits all" is just a waste of time and money. As well as not being very environmentally sound (as Concrete has a lot of embodied energy in it.) Really you aim should be to have the footings as small as they can be for the job it needs to do. No more no less. As an example for my house it generally meant 350 wide x 250 deep footings with Steel reinforcing mesh and an 80-20-20 concrete mix. That is to support a Double brick constructed house on a Sandy Soil. Let the Engineer tell you what you need and maybe save you some $$ in the process (Concrete isn't cheap after all) https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3664 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
