Browse Forums Owner Builder Forum 1 Aug 08, 2011 11:07 pm First time owner builders and just finished the bottom level of our home. Awaiting the suspended slab for the loft to get poured in a few weeks. Really happy so far with it all. Just wondered if anyone had some ideas instead of the regular sliding door pelmet available. We have brick walls which will be plastered. No room for a cavity sliding door into our bathroom. The door will slide into the bathroom. Is there anything else out there to make it look nicer than the normal wooden pelmet of 11 - 12 cm to cover the top of the door. Open to any ideas. Re: Any ideas for a sliding door into a bathroom? 2Aug 09, 2011 11:41 am shame you cant have a cavity slider, because you can buy some that sit inline with your brick wall (ie they form part of the wall, rather than being sandwiched). If we were to put sliding doors to our ensuite and decided not to knock out part of the wall to install a cavity slider, we would be looking at something like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Im not sure where you would find one Re: Any ideas for a sliding door into a bathroom? 3Aug 09, 2011 12:01 pm ^ This - Hafele do something like this - looks fantastic but they cost a bomb - quote for ours was $1700+ for a standard wooden sliding door (just for the track - you need to supply the door). I have found a company call Hillaldam - which are now stocked by Gainsborough do one called the straightway 120 which has an integrated pelmut. Still not fantastic, but the best I have come up with so far! I hope someone has some great ideas as we are looking for an alternative to a chunky pelmut also. DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 13964 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11839 start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 19593 |
