Browse Forums Owner Builder Forum 1 Apr 25, 2011 5:57 pm Hi Guys just contemplating OB and getting prices on my building project. I have a question regarding the termite barrier how many barriers are required? I know I need one between the slab and the timber and brick & some type of barrier where the waste/plumbing pipes come through the slab, but is their a requirment to spray the undersoil before the footings and slab go down? Assistance is much appriciated. Re: Question, Termite barrier under slab requiments 2Apr 25, 2011 8:44 pm I was only required to have a physical barrier installed for slab penetrations (such as drainage pipes) and a perimeter barrier installed around the edge of the house (you can find quite a few pics throughout my blog). I don't think there's any requirement to spray the undersoil as long as you have the physical barrier in place. Re: Question, Termite barrier under slab requiments 3Apr 25, 2011 9:15 pm It is either not both and yes penetrations DO require some detail Where you are coming from is where you are going to... Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3825 I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side… 3 9956 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 15118 |
