Browse Forums Owner Builder Forum Re: What's the best silicone brand for fitting architraves? 2Apr 01, 2011 3:52 pm The architraves get nailed into the door frame. No need to use adhesive. I glue and pin the mitres. The painter will seal down the edge with gap filler if needed. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What's the best silicone brand for fitting architraves? 3Apr 01, 2011 5:16 pm That's it chippy. Gap filler is what I'm after. We will be painting the house ourselves and are trying to make things simpler for us and avoid having to use hap filler on those 45 degree points. We are thinking it would be quicker if we get our carpenter to put it on the angles before connecting... If that makes sense Re: What's the best silicone brand for fitting architraves? 4Apr 01, 2011 9:58 pm Blue, the mitres shouldn't need filling. The chippy should leave them tight. The only spot you should need to fill is between wall and architrave. Even if you do have to fill the mitres I'm pretty sure painters use polly filler rather than no more gaps, it's easier to sand and finish nice and smoothly. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: What's the best silicone brand for fitting architraves? 5Apr 02, 2011 4:05 pm Chippy, is this the poly filler you mentioned? http://www.polyfilla.com.au/content_116.htm My signature is distracting people from my wise posts ... Re: What's the best silicone brand for fitting architraves? 6Apr 03, 2011 9:03 pm I would love to know too I do like the CA glue and activator idea but like you said, working time in non existent. I use the sika PU glue but it needs to be clamped firm. I had a joint move… 4 9214 I already have the doors and architraves installed as pictured. My question is which size n type of skirting would go with the architraves? I originally wanted a winder,… 0 3275 |
