Browse Forums Owner Builder Forum 1 Mar 12, 2011 2:19 pm We are planning an extension ( brisbane ) if I get a builder to lock up stage do I need an OB license to finish off inside. I will be erecting and plastering internal walls, tiling...finishing off in general. I am not sure at which point a licence kicks in. Would appreciate any help.
Re: OB licence question 2Mar 19, 2011 9:57 pm Just call your Local Builders Registration board. They will fill you in as it will be different for each State Good luck https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: OB licence question 4May 05, 2011 5:35 pm able We are planning an extension ( brisbane ) if I get a builder to lock up stage do I need an OB license to finish off inside. I will be erecting and plastering internal walls, tiling...finishing off in general. I am not sure at which point a licence kicks in. Would appreciate any help. Check with you local shire but from my knowledge the construction requires a building licence but the fit out does not, this fit out would include plastering, painting, tiling and finishing Telecommunications systems, computer Networks and Security systems. Re: OB licence question 5May 06, 2011 6:21 am In Victoria, you would need an OB certificate in order to book the final inspection of completion and then be issued a certificate of completion. Re: OB licence question 6May 07, 2011 6:30 pm Your answer ****** here. http://www.bsa.qld.gov.au/HomeOwners/Ow ... lding.aspx You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13124 |
