Just researching septic systems for build in Oakford. Any recommendations appreciated.
Rebecca
Browse Forums Owner Builder Forum Re: Perth -recommendation 4 best type of septic system for r 2Feb 26, 2011 7:17 pm we have septics and a leech drain system. if you go septics try to avoid the pump systems. they are noisy and tend to get located close to the house. Or at least the alarms is/. Noisy because the alarm when they are needing to pump water etc to where ever???? Re: Perth -recommendation 4 best type of septic system for r 3Feb 28, 2011 1:09 pm there are a number of different systems, you can log into the health department's site and find a list of approved systems. Depending on your soil type (ie if there are rocks) then you might want to consider the Atlantis leach system and a Neptune baffle tank. they are a poly system and smaller and lighter to handle that the traditional concrete ones - therefore you could install yourself and get the plumber to do his bit as legally required and there is less digging! If you go with an aerobic system, (we have one), you have the option of then reticulating your garden with the water. Both these types of systems are more expensive than concrete but certainly have other advantages. You can easily google and research the different systems from the health departments list. cheers Shelly Re: Perth -recommendation 4 best type of septic system for r 4Mar 10, 2011 3:52 am Hi Rebecca, We have installed well partially installed a standard septic with leach drains but we used one 4000ltr plastic tank and a grey water diverter wich has its own smaller tank and two nine meter concrete leach drains but you could use the plastic ones it would be up to your local council, all up it cost less than the concrete system, the tank is made by Everhard industries. Hope this helps. Heath Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to… 0 22669 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9780 Hi Renee, Boundaries in NSW are generally shown on Deposited Plans. When they put boundaries into SIX Maps from these plans, there are various reasons that these often do… 1 2020 |
