Browse Forums Owner Builder Forum 1 Feb 15, 2011 5:31 pm Can I build my own lap pool in Queensland? Why cant I..... Lay a rectangular slab, brick up and render 1300mm walls, waterproof, tile. ** I know a licenced plumber would be needed to connect all the pipe work!! Cant see why the cost savings wouldn't be at least 50%? Similarly, Inground rainwater tank. Pick a spot, say under a deck. Lay a slab, brick up 1500mm walls, fit a top with an accessable hatch, instal the deck over. Rainwater tank installed, out of sight! Save not much compared to colourbond, however its out of sight and on a small block takes up no room. Re: BUILDING LAP POOL 2Feb 15, 2011 11:20 pm Have fun!!!!!!!!! Where you are coming from is where you are going to... Re: BUILDING LAP POOL 4Feb 15, 2011 11:34 pm Umm just a tad.... Was that so wrong on every level Where you are coming from is where you are going to... Re: BUILDING LAP POOL 5Feb 15, 2011 11:40 pm toogooi Can I build my own lap pool in Queensland? Why cant I..... Lay a rectangular slab, brick up and render 1300mm walls, waterproof, tile. ** I know a licenced plumber would be needed to connect all the pipe work!! Cant see why the cost savings wouldn't be at least 50%? Similarly, Inground rainwater tank. Pick a spot, say under a deck. Lay a slab, brick up 1500mm walls, fit a top with an accessable hatch, instal the deck over. Rainwater tank installed, out of sight! Save not much compared to colourbond, however its out of sight and on a small block takes up no room. Do you think that the bricks would stay upright with that amount of pressure on them?? Re: BUILDING LAP POOL 6Feb 15, 2011 11:43 pm .. for a while anyway... But who knows I could be wrong Might be time for a search or 2 There are a few posts & threads Where you are coming from is where you are going to... Re: BUILDING LAP POOL 7Feb 15, 2011 11:51 pm Seriously good idea.. but serious waterproofing issues just down the track. Where you are coming from is where you are going to... Re: BUILDING LAP POOL 8Feb 16, 2011 11:49 pm i saw a guy do his own pool on a renovating show it ended up costing him dble what the pool company quoted him unless you know exactly what your doing be very careful it may seem easy but its very technical and could cause major problems if not done properly and you get leaks. if cost is a factor try getting quotes on fiberglass ones or find a pool guy and make him your best mate lol good luck stay safe happy building Re: BUILDING LAP POOL 9Feb 18, 2011 8:52 am If you are serious you can build the frame in this style, (This construction method is how the Vinyl liner companies go about it anyway) Once completed go get a Vinyl liner built to size and installed. Max depth is about 1.2m which is plenty for a lap pool Had a bricky mate do this himself and saved a lot of $$$$ Do a bit of research on Vinyl lined pools and see if it suits your needs. For what it is worth I am having a vinyl lined pool installed for ourselves so I do think they are alright. (Not doing the install ourselves though they can do the lot ) https://forum.homeone.com.au/viewtopic.php?f=38&t=44762 My Owner builder journey extending a 1930's Bungalow Re: BUILDING LAP POOL 10Feb 18, 2011 11:06 am I have a brickie mate who has built a couple of full depth pools now with a vinyl liner ,they are absolute crackers. Re: BUILDING LAP POOL 11Feb 18, 2011 8:52 pm Yep, 2 skins and concrete infill, render and liner Where you are coming from is where you are going to... Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13657 Murraya could be a great option for you. It creates a great tall screening hedge but doesn't drop fruit like lily pilly. The flowers smell divine. 2 10218 |
