Browse Forums Owner Builder Forum 1 Jan 28, 2011 4:17 pm Plumbing rough in, before or after bricks start? Not sure on when to call the plumber back to do the rough in, he said once it has been covered(roof) but the brickie just started to do the bricks and the roof isn't done yet(nest week). I know the poly pipes go in between stud walls but? Any advice? Cheers Re: Plumbing rough in, before or after bricks start 2Jan 28, 2011 4:21 pm It is after the roof timbers go on. Most electricians and plumbers like doing it before the cover goes on as it gives them more space to work in the roof. Nathan Re: Plumbing rough in, before or after bricks start 3Jan 28, 2011 4:27 pm He wanted the roof to go on, I guess its all the rain we have had. I don't think the bricks should matter as he would have to drill out the noggins (spelling?) and studs to run his pipe. My sparkie doesn't care. Re: Plumbing rough in, before or after bricks start 4Jan 29, 2011 8:55 am Befor the bricks. There is more space and it saves time when roughing in the plumbing. If you have a cavity on demand hotwater service your brickie will need it roughed in to know where to fit the box. In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6169 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 7026 5 3775 |
