Browse Forums Owner Builder Forum 1 Nov 09, 2010 10:50 pm So the situation is this... Red Tounge flooring went down, we siliconed all the joins when we laid it as well as all the screw holes to prevent swelling from rain. Since then, we have done the external framework & recently put the roof on but we have also had A LOT of rain. The silicone has obviously minimised it but there is still substantial swelling along all the joins. We need to get the internal framework done & the obvious answer is to sand back the whole floor to level it for the framework. My problem is that without external cladding, a sanded red tounge floor is surely, more likely to swell. We can't do the external cladding until framework inspection takes place. Can anyone shed some light for me on what we should do? "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Re: Red Tounge Swelling & Internal Framing (Steel) 2Nov 09, 2010 11:53 pm my only thought is to just sand the joins where the frame is going for now and if your using foil wrap then wrap the frame asap they can still see the frame from the inside so it shouldnt be a problem for the inspection process and will protect the floor from futher damage. good luck stay safe happy building Re: Red Tounge Swelling & Internal Framing (Steel) 3Nov 11, 2010 6:52 pm Yes, I think thats what we are going to do. We have been told the outside cladding can go on only after framing inspection because we have bracing & the inspector needs to make sure that they are done correctly. We will just have to get it up & inspected asap I guess "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14448 STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5859 8 9910 |
