Browse Forums Owner Builder Forum 1 Oct 05, 2010 9:59 am Hi Everyone We have just purchased a large block of land which we have proposed to subdivide with a builder. Our portion of the land is 1300sqm at the lower end of the block and we intend to do owner / builder with guidance from our builder friend. Does anyone have any advice on retaining walls, cladding, and planns for a very steep incline? We are at the planning stage and would love to hear from anyone who could offer us advice when it comes to steep slope builds. We will have sweeping north facing views over the Barwon River which is the reason we have taken up the challenge of this very steep block. We look forward to hearing from you. Kelli Re: Building on a very steep slope! 2Oct 08, 2010 10:33 pm Hi kellie, Just how steep is your block and things to think about are can you get to the lower end of your proposed builiding are as footings will need to be dug and filled with concrete so access needs to be good and how big is the house going to be the steeper the incline the more costs will go up but if you dont mind the costs then anything is possible. I have a very gentle slope house size of 441sqm on steel piers slope is 400mm one end and other end is 2.5 metres cost of steel flooring system including engineering 49K hope this helps. Regards Heath Re: Building on a very steep slope! 4Oct 09, 2010 12:39 am Hi Kelli, I have owner built built a 535M2 house on a block that sloped 6 metres over the house length some 9 years ago. Not too difficult as long as you do not fight the slope too much. I did 3 cuts with 45 degree batters and built a series of platforms using steel columns, mounted on concrete piles 500 mm out of the ground. Hardi plank sheeting with a zinc skillion roof. If you have space and reasonable soil, batter the banks under the house to 45 degrees and you do not require retaining walls. If you still require retaining walls and have space, then tier them no higher than 1 metre some 1500 apart and you do not require engineering approval. The Light Steel Beam company have steel bearers that span much longer distance than timber on steep land and reduces the amount of footings you need if you are looking for a 'wow' factor. The steel is more expensive than timber, (though for big spans, same or better cost) but when you work out the cost savings in less piers, in often difficult terrain, the cost is soon re-covered.. see ...http://www.litesteelbeam.com.au/liteste ... _view.html Good luck and enjoy the ride. Ged Re: Building on a very steep slope! 5Oct 09, 2010 2:45 pm barkersontheblock Hi kellie, Just how steep is your block and things to think about are can you get to the lower end of your proposed builiding are as footings will need to be dug and filled with concrete so access needs to be good and how big is the house going to be the steeper the incline the more costs will go up but if you dont mind the costs then anything is possible. I have a very gentle slope house size of 441sqm on steel piers slope is 400mm one end and other end is 2.5 metres cost of steel flooring system including engineering 49K hope this helps. Regards Heath I think that was very great project, building on a very steep slope. Well, for me it is better the filled is a concrete. Yeah, it is more cost for that project but I think result was very great. My Cost seo services Re: Building on a very steep slope! 6Oct 09, 2010 10:07 pm We have just finish building with a builder on a 6 meter fall over the building zone. My advice would be design the house to follow the fall of the land to reduce exavation cost we have used a combination of slab & stumps, use light wieght material like colourbond & hardies cladding products which will reduce the wieght of your build, and remember to think outside the square. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Building on a very steep slope! 7Nov 28, 2010 9:19 pm We are in a similar situation - very steep site but worth it for the views! We are cutting into the site to build in a basement/garage which will result in high concrete filled retaining walls, but we feel it will be very useful space and worth the cost. Luckily our soil is stable but we did need to get a geotechnical engineering report to OK it for council and building. I'll let you know when we get a quote for the cost of the walls :p Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 356749 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223474 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24830 |
