Browse Forums Owner Builder Forum Re: Chippy's Build. Upper floor brick work completed. Pic's 81Feb 14, 2011 9:55 pm Does look impressive. I was curious to know why you went the concrete formwork upstairs instead of light weight? The latter being less expensive and all, at least I thought. Re: Chippy's Build. Upper floor brick work completed. Pic's 82Feb 14, 2011 10:26 pm Never skimp on the Pâté Where you are coming from is where you are going to... Re: Chippy's Build. Upper floor brick work completed. Pic's 83Feb 15, 2011 9:52 am aza0 Lookin good! How much extra $'s do you think it has cost you to go to reverse brick veneer construction over a normal brick construction? The reason I ask is that my builder has added $26,000 premium to go reverse brick veneer based on 176sqm area. Single story home. Hi Aza. When my estimation came in, he had estimated an extra cost of $3300 over and above regular double brick and render to do the 76 m2 of the western wall. I worked out a basic cost of about $5000 to supply bricks, have them layed and plastered with acrylic render for this area. So far I've spent around $1300 to get all the framing completed and fixed. Now I have to insulate and sheet it, then get it painted. Hopefully I should come out just in front. This doesn't allow for my labour though. If I was charging this as a job I'd probably charge around the $3-$3.5k mark, so the estimate was pretty close to right. Long term though the house should be far more comfortable and use less energy. The amount of heat that wall absorbs in summer is incredible. Any way to stop it entering the house while still maintaining solid brick internal walls is a real bonus. The other option would be to get cavity insulation. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Upper floor brick work completed. Pic's 84Feb 15, 2011 10:05 am donR Does look impressive. I was curious to know why you went the concrete formwork upstairs instead of light weight? The latter being less expensive and all, at least I thought. onc He is right. Over here in the wild west we like our buildings solid. We build double brick which means our structural walls are brick, this then gives you the option of building suspended concrete floors. Because this is the way the building industry is focused over here the cost is close enough that you wouldn't bother using light weight alternatives (or I wouldn't). I love the feeling of a nice solid concrete floor under foot. We have kids and I don't want to hear them thudding around upstairs. It also means I've only got a 258mm floor spanning spanning 8.6m. I'm not an engineer but I'd suspect you would end up with some pretty big bits of steel to span those sorts of distances. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Upper floor brick work completed. Pic's 85Feb 15, 2011 10:17 am That makes sense, I do recall most houses in Perth being double brick and it is very hot over there. The reverse brick veneer makes sense given the outside of your house will cool down quicker whilst your thermal mass on the inside should stay more constant. I have seen a couple of houses like that on the east-coast. However, over here normal brick veneer and lightweight top levels dominates most homes which I guess achieves some enconimies of scale given the demand and prefabrication of all the framing. Re: Chippy's Build. Roof framing, plumbing and electrical. P 86Feb 28, 2011 12:11 am The roof is done! The roofy took a week to pitch the roof. He finished last Monday. The Sparky and Plumber have been in and got their gear in. Now the gutters and roof sheeting start tomorrow and should take a week. Some Pic's: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Halfway through the roof being pitched Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Finished job Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Plumbing over kitchen The trouble I now have is that both my plasterer and ceiling fixer have both decided to go on holidays for 2 weeks in the middle of March. So I now have to get the roof sheeting finished. Then solar HWS, solar PV panels, air conditioning and antenna installed. Then get the scaffold dropped so I can install the cladding on the rear wall, then the plastering can start. I can then get the ceilings and cornice done. All in the next 3 weeks! If I can organise it all, the house will be flying along. If there is one hiccup, it will all stop while my tradies are sunning themselves in Bali. I expect something will crop up to slow it down. But I cant complain, all in all it is going well. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Roof framing, plumbing and electrical. P 87Mar 02, 2011 5:15 pm hey chippy - you are doing a great job... love the progress so far... wish I knew as much as I know now coz I would've gone OB as well... Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Chippy's Build. Roof framing, plumbing and electrical. P 88Mar 03, 2011 12:42 am looks great chippy hope all goes to plan with the plastering fingers crossed for you stay safe happy building Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 89Mar 07, 2011 1:14 am Bagheera, next time you can owner build. It's been full steam ahead at our place. The roof plumber has finished the sheeting. I'm very happy with the job. We went for surfmist colour bond as it is the most efficient colour. We went with nice quarter round gutters as they add a real contemporary look. The solar HWS has been plonked on the roof. The plumber will be through on Tuesday to hook it up and make sure there are no leaks before we drop the scaffold. The Solar PV panels and antenna will be installed on Tuesday as well so should have a very busy site. I've managed to get things done fast enough that my renderer will be able to come next weekend to start the external render and will finish it before he goes away. I ended up getting another quote on the ceilings and have saved myself $2000 and it can be done on my time frame so very happy with that. I wasn't going to be able to get things ready for the other ceiling fixer I had lined up but it ended up working out better anyway. The scaffold will come down on Wednesday afternoon or Thursday morning so I have time to sheet the rear wall on Thursday and Friday before the renderer starts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The roof in all its glory Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Roof over entry and blade wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Quarter round gutter Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Solar HWS Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 91Mar 13, 2011 11:37 pm Thanks Missy. I must admit, I'm really enjoying OB'ing. So much so that I'm considering doing my builders registration. I've looked at it before but it seems the right time to put the extra skills I'm learning into practice. I am in awe of the guys on here that OB with no prior experience. My head spins at times with all the things you need to have in mind. It must be really something if you dont have a great deal of trade experience. Good tradies are really the essence of OB'ing. If you surround yourself with people you can trust then it makes the whole process easier particularly if you aren't full bottle. Seems like your plan is getting a few nice tweeks in the custom thread. When do you plan to start? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 92Mar 14, 2011 12:23 am We've had another good week of action. The plumber and sparky have been busy getting their thing done. The aircon guys got their pre-lay in on Tuesday. The solar PV panels (16 in total) were installed on Wednesday and the scaffold came down later that day. Thursday was my day to get in and start sheeting the upstairs RBV. Made some good progress but had to go and make some money on Friday so wont get back until the following week to finish up. The external renderer got all the float on the upstairs on Thursday and Friday. He was going to texture the upstairs on Tuesday however we decided to leave it until the internal is floated. The last thing I want is grey plaster all over my nice white texture. My priority now is getting the scaffold down as it costs big $$$ every week it is up. I've ordered my glass for 2 weeks time which will give me time to get the internal float finished and ceilings installed then glass in and internal set and external render done. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Air Con ducting. There wiring is so messy compared to the sparky Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Solar PV panels Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Scyon Axon panels on RBV I'm starting to dream about an August finish. It would be awesome if I could, but I know the finishing stages will be largely dependant on me, so I'm expecting it to slow somewhat. My Wife would be happy if I took the rest of the year off so I can just work on our place. It would be nice but the pesky kids need to eat. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 93Mar 14, 2011 12:53 am Looking awesome Chippy. Wow! I think you should get your builders licence. I was told that in the next few years they are changing to rules to make it shorter course but with some changes as to what you can and cant do. I must ask my tiler because he is in the middle of it but has decided to wait for this. It seems a much more sensible way to do it but I can t remember what it was! Are you having acrylic render. I decided against it in the end because I was freaking out about the damage that can get done to it. And over the size of our house it was going to cost a bloody fortune! Seems we could have similar move in dates. Are you making your kitchen and other cabinets? I ordered mine yesterday and am about to sign off on laundry and ensuite. Well done .... you are doing an amazing job! kay Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 94Mar 14, 2011 9:57 am Hi K, thanks for that. I decided on acrylic texture. I vacillated between sand finish & paint or acrylic texture. There are pro's and cons for each. I definitely think that acrylic texture is the nicer looking finish. The colour is a lot deeper because it is right through the product. It is also slightly elastic so has a slight ability to not show cracks or movement in the underlying render that would show through regular paint. The problem with acrylic texture is if it is damaged. You cant just patch a small area like you can with render & paint, you need to patch entire walls. My renderer has recommended not texturing the ground floor until as far as possible towards the end. Hopefully this should mitigate any clumsy tradies damaging my nice new walls. The price wasn't as big an issue as I thought. Sand finish render is about $24m2 and external painting I had quotes of $10-$16m2 . My texture is costing $36m2 so price works out about the same. Ultimately I dont think it really matters. Good friends of mine OB'd their houses right next to each other. There houses are very similar. One is a painter so went for sand finish and then he painted it. The other went for acrylic texture. When you stand on the street and look at their houses you cant tell a difference. You just have to go with what is going to suit you and your hip pocket better. I'm doing my own cupboards. As soon as the internal float is done I can get in and measure up for all the upstairs bathrooms. I can see that I'm going to start to get very busy soon. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 95Mar 14, 2011 11:07 am Hi Chippy,how many kws did you get for solar are the panels German made.Do you think it wil meet all your electricity needs Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 96Mar 15, 2011 10:36 pm chippy Thanks Missy. I must admit, I'm really enjoying OB'ing. So much so that I'm considering doing my builders registration. I've looked at it before but it seems the right time to put the extra skills I'm learning into practice. I am in awe of the guys on here that OB with no prior experience. My head spins at times with all the things you need to have in mind. It must be really something if you dont have a great deal of trade experience. Good tradies are really the essence of OB'ing. If you surround yourself with people you can trust then it makes the whole process easier particularly if you aren't full bottle. Seems like your plan is getting a few nice tweeks in the custom thread. When do you plan to start? Do it, do it, do it! Then you can come to Melbourne and build my house!!!! Yes, I've had some good advice on the other thread, although I may just have put a spanner in the works tonight. You'd better go and have a look . My husband rang me from work this morning telling me he is having second thoughts, and perhaps we should check out the volume builders AGAIN. We'd look at those who do a reverse living arrangement. However, as I've been re-reading your thread and ogling the pictures, it has just dawned on me that a builder friend offered to project manage our build. I thought that just meant he'd be the builder, but I'm wondering if I'm not quite on the money. Anyway, I'll have a chat with him and see where that goes. I would SO love to OB - problem is though that the bank probably won't lend us money for that (long story). My other desire is to have a concrete slab - for thermal mass predominantly, but I'll take the polished concrete as a side benefit , and if we end up with a double storey, dare I even dream about concrete up there??? Maybe if we were OB's I could! Night Chippy! Re: Chippy's Build. Solar panels & aircon. Pic's 97Mar 15, 2011 11:16 pm HI Chippy You are doing so well. I am so jealous that you can make your own cupboards ... fancy doing mine? I would have been a great carpenter .. full of good ideas. For the bathrooms in the kids bedroom and loft I am just going to go to Reece. I cant be bothered going to cabinet makers and them charging the world for ordinary. Our white set starts in the next few days so it should look like a real house very soon. Even I am getting excited now! Keep up the awesome work and do your builders licence ... you would be great at it! Re: Chippy's Build. Roof sheeting and solar HWS. Pic's 98Mar 16, 2011 1:27 am pattycake4 Hi Chippy,how many kws did you get for solar are the panels German made.Do you think it wil meet all your electricity needs Hi Patty. We opted for a 3kw system. It should go close to meeting our power needs in normal situations, however our aircon is 24kw so I guess when that is cranked up then we will be paying through the nose. But we have paid a lot of attention to getting the house fairly thermally efficient so hopefully we will cut down on the use of aircon to a bare minimum. The panels are Chinese made and the inverter is German. After a fair bit of research and discussion with people I decided that it wasn't an issue where the panels were made. People have this perception that German panels are best but the tier one Chinese panels are a very high quality. The company I went with are actually a distributor and have been around for a long time and will be around for a long time. They were happy to show me the quality of there products and the walk me through their warehouse. They actually weren't the cheapest quote I had but I felt very comfortable that if I had any issues in the future they would still be around and happy to deal with it. With the way electricity costs are going up I'm sure it is a decision I wont regret. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Solar panels & aircon. Pic's 99Mar 16, 2011 1:38 am kayandandy HI Chippy You are doing so well. I am so jealous that you can make your own cupboards ... fancy doing mine? I would have been a great carpenter .. full of good ideas. For the bathrooms in the kids bedroom and loft I am just going to go to Reece. I cant be bothered going to cabinet makers and them charging the world for ordinary. Our white set starts in the next few days so it should look like a real house very soon. Even I am getting excited now! Keep up the awesome work and do your builders licence ... you would be great at it! You'd have to get in line if you wanted me to do your cupboards. I do agree that cabinetry costs a lot for not much. If you are having your set done you are ahead of me. Your place is moving nicely now. Sounds like it will come together fast. I still plan to get past and have a look. I'll let you know when. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Chippy's Build. Solar panels & aircon. Pic's 100Mar 16, 2011 1:18 pm thanks Chippy,good information 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3924 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 710 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47011 |
