Slab higher than front footpath
I'm building in southMorang and my land is ona very slight slope, the builder who I am going with is telling me that my slab is going to be higher than the front foot path but 10cm, Is this correct? or is it he does not want to dig down? I'm so puzzeled the last thing I want si to see a slab from the front of my house once finished
One side of my house is lower then the road, and one is higher than the road due to the slope of the block.
Hard to know without pics of your block, but I wouldn't be worrying.
Depending on the directional slope of your land 10cm doesn't seem like much of a difference. As long as it isn't going to affect your driveway approach angles I wouldn't worry about it.
13
interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing…
30/10/2023
Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section…
25/05/2023
1
Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off
