Browse Forums Owner Builder Forum 1 Aug 06, 2010 10:40 am What material is usually used to "close off" the eaves? Hardiflex or villaboard? Or are these two the same thing, just different names? Or do they use something else instead? Also, what thickness? Any tips/hints when choosing/installing? Re: What material is used to "close off" the eaves? 2Aug 06, 2010 10:55 am Hardiflex for outdoors Villaboard for internal Hardiflex in 4.5mm & 6mm Villaboard 6mm, 9mm,12mm. Where you are coming from is where you are going to... Re: What material is used to "close off" the eaves? 3Aug 06, 2010 7:36 pm Eaves fibro is 4.5mm and comes in 450mm and 600mm widths Different to what others have said but thanks for that insight. 2 5201 Not recommended! The image presented is for a sublevel area. The footings are down deep with a load bearing wall supporting the upper floor level. If you did that drain… 8 10591 Always get multiple quotes, no matter how reasonable/cheap you think it is. I remember getting a few quotes for a pool fence, roughly around the same price, thinking the… 5 9686 |
