Browse Forums Owner Builder Forum 1 Jun 03, 2010 9:17 am Our steel frame was on the ground and for months before it got put up. As a result there is a lot of dirt all over it now. Do you think it would be worth washing it or would you not worry about it? Washing the wall frames is not an issue I guess but floor joists and trusses would be a bit tricky to wash (as they have now been put up). What do you guys think? Re: Would you bother washing the frame? 2Jun 03, 2010 5:41 pm Hi there. Heck no- read a book instead! As a builder I have seen a lot of dirt on a lot of frames, but once they are clad there is no problem at all. Just think that the steel comes from dirt too (iron ore)! Cheers, Dennis Re: Would you bother washing the frame? 3Jun 04, 2010 10:04 pm It might be a good idea to check if any corrosion has occurred while the frame was sitting on the ground. Our frame was delivered a week before it was installed but we it was kept off the ground using wooden bearers. If the frame has got lots of mud (thick layers or patches) it might be a good idea to clean them off. Usually once the roof goes on and the mud dries it will brush off easily. If you've got any concerns contact the manufacturer of the steel framing system. This is 100% true. You can not hang anything on steel frames. very frustrating 8 8014 Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17520 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8772 |
