Browse Forums Owner Builder Forum Re: Bricklayers & wastage of bricks - what's acceptable? 2Jun 01, 2010 2:39 pm there is no acceptable amount or figure. Each house is different. Here are the variables. - Type of Brick - Batch of Brick - Design of house - Has the house been design to brick measurement? - Have you got a brick cutter to cut bricks or are they been cut by hand. - Are you leaving out chipped bricks?? Re: Bricklayers & wastage of bricks - what's acceptable? 4Jun 02, 2010 7:50 pm Depends a lot on the design of the house. "Average" I'd say is about 10%. Built a Tribeca 44 with the Big M Sales Accept 15/06/09, Contract Signed 24/09/09, Site Start 23/11/09, Slab 11/12/09, Frame 12/01/10, Roof 20/01/10, Lock-up 30/03/10, Fixing 30/04/10, Handover 27/08/10. Re: Bricklayers & wastage of bricks - what's acceptable? 6Apr 08, 2017 6:23 pm no its 20%, why u worried about this, do u want th brickys to put chipped bricks in ur house, NO, then stop being tight with ur$$$ Re: Bricklayers & wastage of bricks - what's acceptable? 7Apr 09, 2017 10:51 am hiccup What is the acceptable percentage of damaged bricks? By damaged I mean they've cut them wrong, covered in mortar etc. Hiccup 5% to the nearest pack The design software builders use now can calculated the bricks quants fairly accurately. Make sure you check all quants/bricks supplied, invoiced,delivered,waste, buried on site and count the packs used daily. 10%->20% extra Co$t is better in your pocket Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Available on Google Sheets PM or email me appsb4ubuild(at)gmail(dot)com Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Bricklayers & wastage of bricks - what's acceptable? 8Apr 09, 2017 5:29 pm that software doesn't account for what type of bricks they are. Some bricks are brittle and chip a lot easier than others, sometimes you get bundles that every bricks header has a hair line crack thru it. Generally it's better to order more than less, because sometimes if u have order an extra 500 bricks they could be a different shade because they weren't cooked in the same batch and if the bricks are untouched and easy to access the brick company will come pick them up for free. Re: Bricklayers & wastage of bricks - what's acceptable? 9Apr 14, 2017 10:18 am That's a quality control issue that needs to be taken up by the purchaser with the brick manufacturer. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Bricklayers & wastage of bricks - what's acceptable? 10Sep 06, 2018 2:42 am StructuralBIMGuy That's a quality control issue that needs to be taken up by the purchaser with the brick manufacturer. Re: Bricklayers & wastage of bricks - what's acceptable? 11Oct 11, 2018 3:40 pm perfectbond that software doesn't account for what type of bricks they are. Some bricks are brittle and chip a lot easier than others, sometimes you get bundles that every bricks header has a hair line crack thru it. Generally it's better to order more than less, because sometimes if u have order an extra 500 bricks they could be a different shade because they weren't cooked in the same batch and if the bricks are untouched and easy to access the brick company will come pick them up for free. It’s good practice to open up at least 3 packs and mix them up , you should never just use one pack at a time. Re: Bricklayers & wastage of bricks - what's acceptable? 12Oct 11, 2018 7:32 pm Tim65 perfectbond that software doesn't account for what type of bricks they are. Some bricks are brittle and chip a lot easier than others, sometimes you get bundles that every bricks header has a hair line crack thru it. Generally it's better to order more than less, because sometimes if u have order an extra 500 bricks they could be a different shade because they weren't cooked in the same batch and if the bricks are untouched and easy to access the brick company will come pick them up for free. It’s good practice to open up at least 3 packs and mix them up , you should never just use one pack at a time. Re: Bricklayers & wastage of bricks - what's acceptable? 13Oct 11, 2018 7:35 pm kathysangel StructuralBIMGuy That's a quality control issue that needs to be taken up by the purchaser with the brick manufacturer. Re: Bricklayers & wastage of bricks - what's acceptable? 14Oct 11, 2018 7:35 pm kathysangel StructuralBIMGuy That's a quality control issue that needs to be taken up by the purchaser with the brick manufacturer. 1 4598 1 13209 I wanted to get some thoughts on the quality of workmanship on the following brickwork? are there specific clauses in Australian Standards which relate… 0 4855 |
