Hi All, we've received two roofing quotes, problem is one specifies 425/LM and the other 340/LM of 762mm wide Colorbond sheeting.
The house is ~190sqm and the roof pitch is 25 degrees, due to the design there are quite a few different roof planes.
Does someone know the approximate linear metres of Colorbond roof sheeting required for this size roof?
I was thinking it would be closer to 340/LM allowing for overlap, pitch, etc. but the 425/LM estimator was sure his quote was correct
