Browse Forums Owner Builder Forum 1 Mar 06, 2010 8:22 pm Hello. We just wanted some opinions about R-code storage area. (We are in Perth northern suburb) Our building designer is telling us that we must have 4sqm storage area within the garage as we have a small block (316sqm) and haven't got much space outside. According to R-code Section 6.10.3, A3.1, it does say Essential facilities but does not say we must have it. When we were considering using a builder, none of their plan had a storage inside the house. It would be great if we could hear some opinions. Thanks! Re: Advice needed about R-code for storage area 2Mar 06, 2010 11:22 pm 4 square metre is the requirement. We have recently subdivided our block and the front house managed to slip through without a requirement to provide for a storeroom. When I was talking to a planner from the council he noticed this and said it was because our lots have no common property the existing house was deemed to comply with a single home, and therefore did not need a storeroom. Our house on the rear lot that we have just had designed does have a store area off the garage. Personally I think 4 metres isn't enough. You can never have enough storage. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Advice needed about R-code for storage area 3Mar 07, 2010 9:21 am Thanks Chippy. We have a storage somewhere else (40FT sea container), so we were hoping to have more living space inside. Try our best to figure this one out then. Really appreciated for your advice, thanks again! Re: Advice needed about R-code for storage area 4Mar 07, 2010 12:37 pm perthben Hello. We just wanted some opinions about R-code storage area. (We are in Perth northern suburb) Our building designer is telling us that we must have 4sqm storage area within the garage as we have a small block (316sqm) and haven't got much space outside. According to R-code Section 6.10.3, A3.1, it does say Essential facilities but does not say we must have it. When we were considering using a builder, none of their plan had a storage inside the house. It would be great if we could hear some opinions. Thanks! We too are building in the northern suburbs, we have a cottage block 307sqm and it is a requirement that we have a 4sqm storage area, with a rear garage, which we are quite happy to have as we cannot have a shed on the property. I have been lead to believe that the plans will not be approved by Planning or the developer's planning section without this storage area. We also have to have a 2m solar setback on the eastern side which is a lot when you have a 10m frontage. There are ways around this if you do not have any major openings on that side but your planning section of your local council will explain that to you. Have you chosen a builder yet? Re: Advice needed about R-code for storage area 5Mar 07, 2010 2:26 pm Hello Davcaff11, Thanks for your message. Mmm... it's getting harder now. We are doing an owner builder. The garage storage part is adjascent to our kitchen/dining/lounge area so we just want to make the storage a little smaller to have a bigger lounge. We have another storage area in the different section of the house but it's not going to be counted as there is no access from outside/garage. After we started working on the design, we realised so much restrictions with narrow blocks! 2m solar setback must be very difficult for you too. Are you building with a builder? We'll check with the council and make a decision. Thanks a lot! Re: Advice needed about R-code for storage area 6Mar 07, 2010 10:44 pm davcaff11 We too are building in the northern suburbs, we have a cottage block 307sqm and it is a requirement that we have a 4sqm storage area, with a rear garage, which we are quite happy to have as we cannot have a shed on the property. I have been lead to believe that the plans will not be approved by Planning or the developer's planning section without this storage area. We also have to have a 2m solar setback on the eastern side which is a lot when you have a 10m frontage. There are ways around this if you do not have any major openings on that side but your planning section of your local council will explain that to you. Have you chosen a builder yet? Is the 2m setback a council requirement or a requirement of the estate. The R codes seem to specify a 1.5m minimum setback to habitable rooms with major openings. There is a house being constructed down the road from us (city of Stirling) on a 10m frontage that is built boundary to boundary with double storey parapet walls both sides. The R codes can be massaged quite hard by a good designer to maximise your lot. Covenants put down by the estate may not be quite as flexible. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Advice needed about R-code for storage area 7Mar 13, 2010 12:59 am just a thought but why not have an attic storage space? unless you are going with a flat roof of course. My Owner still Building thread viewtopic.php?t=9026 Re: Advice needed about R-code for storage area 8Mar 13, 2010 11:21 pm In WA our planning commission dictates that strata developments have a storage area of 4m2 that can be accessed from either outside or incorporated into the garage. This is really to take the place of a garden shed or similar that isn't able to be installed in the limited space available on strata lots. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16553 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8451 |
