Browse Forums Owner Builder Forum 1 Jan 25, 2010 8:28 am Ok so the kit is 8 wks away. What on earth is the order we should be doing things in? It is a small kit home raised about 400m & the kit includes nothing for internals, no walls, insulation, doors etc. Just structural steel, roof, external walls, suspended flooring system & gutters. So what order should we do things? My guess is as follows: 1. Move some dirt, level out the ground 2. Dig the trenches for septic & dist boxes etc? 3. Dig holes for suspended flooring system? 4.? "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Re: What to do next? 2Jan 25, 2010 9:35 pm 1- Order your windows if they don't come with the kit as they can take some time to arive 2-Site establishment, such as signage and erosion control measures like silt fences. 3- Level the site as required in 300mm max layers at a time and compact each layer. 4-Underground services: get plumber and electrician to put in the required services and stormwater drainage. 5- Excavate and pour piers or footing system. Plan and schedule things ahead of time particularly if you need a tradesman to attend on a certain date. Choose your PC items such as toilets, baths and sinks and also the desired location as knowing this from the start will save time and money in the long run. Good Luck. Re: What to do next? 3Jan 26, 2010 1:29 am if you havnt got power to the site then ring them asap as it can take up to 3 months depending on where u live stay safe happy building Re: What to do next? 4Jan 26, 2010 8:23 am Bingoshelley-we do have power on the site as this is the 3rd home on the site. ARK- Thank you for the heads up about the windows, I will certainly get onto that. "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Re: What to do next? 5Jan 29, 2010 5:11 pm serialstyler Ok so the kit is 8 wks away. What on earth is the order we should be doing things in? It is a small kit home raised about 400m I would start off by buying a very very long ladder. JB Re: What to do next? 6Jan 31, 2010 4:17 pm Ha Ha. 400mm good call JB! "A dream you dream alone is only a dream. A dream you dream together is reality" -John Lennon Re: What to do next? 8Feb 01, 2010 1:23 am James Bond serialstyler Ok so the kit is 8 wks away. What on earth is the order we should be doing things in? It is a small kit home raised about 400m I would start off by buying a very very long ladder. JB Bazingah... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16126 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20295 Did you know that you can get rugs made from carpet? So much cheaper than buying a shop rug. So many styles to choose from, but you won't get the highly patterned… 0 6368 |
