Browse Forums Owner Builder Forum Re: Fibre Cement Compressed Sheet - in Wet Areas 8Dec 12, 2016 10:32 am 1500 mm by 900mm compressed fibro sheet can be 27 kg or 31 kg per cubic m. Its thickness is only 15mm where as hebel powerfloor is 75 mm almost as thick as a 76mm brick or 3 inches. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4493 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3160 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7122 |
