Browse Forums Owner Builder Forum 1 Jan 20, 2010 2:44 pm We are using Hebel PowerFloor for the upper floor and originally wanted to use the same in wet areas. However, we recently found out that this requires the joist to either be set down or reduced to allow for recommended 50mm wet area set down or you can fully waterproof area with membrane. It seems like our steel frame supplier hasnt set down the joists and we are thinking of using Compressed Sheet in wet areas. Appearently it provides an automatic set down due to thickness difference compared to PowerFloor... Has anyone used compressed sheet and what was your experience? Is it the way to go? Re: Fibre Cement Compressed Sheet - in Wet Areas 2Jan 20, 2010 5:02 pm Yes, I've used it many times. Still requires waterproofing though as normal. Use it for small exterior balcony, water proofed with a couple of coats then tiled over the top. No hassles since then. Most of the applications have been exterior balconies i might add. Re: Fibre Cement Compressed Sheet - in Wet Areas 4Jan 22, 2010 8:45 pm Compressed fibro is good stuff. Only problem is the weight. there is another product out now called Scyon™ Secura from Hardies. Follow the link for installations procedures. The link will also show right applications for the product. Hope this helps Cheers Re: Fibre Cement Compressed Sheet - in Wet Areas 5Jan 23, 2010 2:56 pm kryan05 Compressed fibro is good stuff. Only problem is the weight. there is another product out now called Scyon™ Secura from Hardies. Follow the link for installations procedures. The link will also show right applications for the product. Hope this helps Cheers Thanks for that. So compressed sheet is heavier than Hebel powerFloor? Re: Fibre Cement Compressed Sheet - in Wet Areas 7Dec 12, 2016 10:30 am gettingThere kryan05 Compressed fibro is good stuff. Only problem is the weight. there is another product out now called Scyon™ Secura from Hardies. Follow the link for installations procedures. The link will also show right applications for the product. Hope this helps Cheers Thanks for that. So compressed sheet is heavier than Hebel powerFloor? No it can not be heavier than hebel powerfloor which is 56 kg per sqm. Re: Fibre Cement Compressed Sheet - in Wet Areas 8Dec 12, 2016 10:32 am 1500 mm by 900mm compressed fibro sheet can be 27 kg or 31 kg per cubic m. Its thickness is only 15mm where as hebel powerfloor is 75 mm almost as thick as a 76mm brick or 3 inches. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4494 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3161 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7128 |
