Browse Forums Owner Builder Forum 1 Oct 25, 2009 6:38 pm Hello, can anyone suggest a good solid timber floor installer & sander in Sydney please? big companies like Timber Flooring & Sydney Flooring do not do installation only as I am able to get solid Boral timber flooring at a good price thanks ttn Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15919 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8317 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3280 |
