Browse Forums Owner Builder Forum Re: Rec for strip footing company MELB 12Jan 31, 2010 7:58 pm hunts01 A wise person once told me you can never ask a silly question. The footings are basically the supports that the brickwork sits on, they use it to 'tie' in the house. Your footings for the brickwork may be 450 to 600 mm wide and the same deep, and the brickies will brick up on this. Whether or not you do your garage now or later doesn't really matter. The footings may have a nominal depth of say 400mm or to natural ground, the garage definately will not be the same depth, so to paint a picture the footings depth wont continue across your garage slab, like a big slab, the footing will be whatever the engineer specifies, the garage slab will just be to standard specifications, unless you are having a suspended garage floor or something tricky like that, which is above my head.! Us for example have our footings 600mm wide, 450 deep (retaining wall as well). The garage slab will be on natural ground level which is the height of the top of the footings, the slab will however tie into the strip footings as they are about 400mm away from the brick work wall. (if that makes sense)!! I had to re-read the post twice, but now I understand! Thank you for sharing your knowledge Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7314 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10230 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3312 |
